Computer Audio Setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 11-17-2010, 05:33 PM - Thread Starter
Displaced Husker's Avatar
Quoted: 13 Post(s)
I would like to improve the sound quality of my computer music only setup. My setup is as follows:
*Dell 3000 Dimension 2Gig Ram
* Windows XP
*External Hard Drive (Music is Stored On)
*Soundblaster Audigy LS
*Analog "Y" connector to:
*Dell Desktop Speakers &
*HK AVR500 Receiver (Has digital capabilities)
*Monster Speaker Selector
*3 Volume Controls
*3 Sets of Speakers (JBL in wall) & two sets outdoor speakers
*Itunes most of my music is ripped MP3 192 kbps. I began switching to Apple Lossless
* I control Itunes from my iPhone.
I recently became unhappy with the sound. I was getting some distortion and switched from using my motherboard soundcard and installed an Audigy a friend had (disabled the soundcard's and deleted the driver). I also changed a 25 year old NAD receiver that I was using with a 10 year old Harmon Karden that I replaced in my home theater. Better but not quite there. I listen at my computer 75% of the time & the other locations 25% of the time.
I tried to hook the soundcard's 1/8 connect to the digital coaxial with a 1/8 mono to RCA cable (needed to use a RCA connector and an additional RCA cable) on the HK with no luck.
What's are my next steps to get improved sound at both my desktop (I know speakers) and the HK?
Displaced Husker is online now
post #2 of 18 Old 11-17-2010, 07:24 PM
dknightd's Avatar
Originally Posted by Displaced Husker View Post
(I know speakers)
that is where I'd start. Especially if you listen 75% in front of your computer. You can easily do better than Dell speakers. . .
Everything I say here is my opinion. It is not my employers opinion, it is not my wife's opinion, it is not my neighbors opinion, it is My Opinion.
dknightd is offline
post #3 of 18 Old 11-17-2010, 07:48 PM - Thread Starter
Quoted: 13 Post(s)
Is the Y connector and analog is OK? Do you have any recommendations on powered speakers? Logitech-Klipesh-Harmon Karden (except they look funny)seem to be what the masses like.
post #4 of 18 Old 11-17-2010, 08:29 PM
dknightd's Avatar
I don't know what your budget is, or where you live, or what you like in sound, but for a reasonably priced 2.1 computer speaker system I think it would be hard to beat these at their sales prices. Assuming you have space to place them.
http://www.parts-express.com/pe/show...631&FTR=sub-80
http://www.parts-express.com/pe/show...number=300-650
for $140 total they work pretty well. You can better, but, that would cost more money.
dknightd is offline
post #5 of 18 Old 11-18-2010, 05:48 AM - Thread Starter
Quoted: 13 Post(s)
I have a nice JVC office system that I don't use that will work great I will just add a subwoofer to it.
Next questions
Does leaving the JVC & the Harmon Karden on with no input use a lot of energy or cause damage to the units?
My living room has a Niles volume control fed by two speaker wires - wired to in-wall speakers. Can a subwoofer be added after the Niles?
Is using the analog out from the computer and the Y the best way to go or would I see a dramatic improvement in what I am doing by going digital?
post #6 of 18 Old 11-18-2010, 06:03 AM
dknightd's Avatar
Leaving the units on all the time will use some energy. Shouldn't do them any harm.
Don't know about the niles.
Most built in computer soundcards are not very good. You might benefit by using digital output. Only you can decide if the difference is dramatic. FWIW I go digital out from the computer, and think it is worth it.
dknightd is offline
post #7 of 18 Old 11-18-2010, 11:12 AM - Thread Starter
Quoted: 13 Post(s)
can you go digital to two locations?
post #8 of 18 Old 11-18-2010, 12:49 PM
dknightd's Avatar
There are digital audio splitters. I've not used one, but assume they work.
dknightd is offline
post #9 of 18 Old 11-18-2010, 01:23 PM
oldblackcrow's Avatar
I hooked up my motherboard soundcard to my onkyo receiver via the coaxial port. I then use my Droid as an interface for my computer. Beautiful sound. I did, however rip all my CD s to Wav for superior fidelity. I'm running Magnepan MMGs for my speakers. Yum. :-)
oldblackcrow is offline
post #10 of 18 Old 11-18-2010, 10:29 PM - Thread Starter
Quoted: 13 Post(s)
I believe iTunes is causing the source of my dissatisfaction. I can play a CD on my computer and it sound great. The same files through iTunes sound no where near the same. It is muffled and the voices sound distorted. My only issue is I like to control the sound with my iPhone.
post #11 of 18 Old 11-18-2010, 11:29 PM
c.sperling8's Avatar
Have you tried media monkey?? it is leagues better than itunes.
c.sperling8 is offline
post #12 of 18 Old 11-18-2010, 11:53 PM
acebreathe's Avatar
Quoted: 172 Post(s)
Liked: 99
Media Monkey is good so is Foobar. Could run diagnostics in itunes to make sure its running right.
acebreathe is offline
post #13 of 18 Old 11-19-2010, 05:44 AM - Thread Starter
Quoted: 13 Post(s)
Is there a remote option or a iphone app for either
post #14 of 18 Old 11-19-2010, 06:00 AM
dknightd's Avatar
If you have not already, disable all playback effects in iTunes. Especially turn off "sound enhancer". That might help. And compare a lossless CD rip with the CD. They should sound the same.
You could google media monkey, or foobar, and iphone app. They are probably out there.
dknightd is offline
post #15 of 18 Old 11-19-2010, 06:19 AM - Thread Starter
Quoted: 13 Post(s)
I have had all those items turned off and have changed to lossless and tried all the other formats. It is a night and day difference between playing the CD and any format.
I also tried enabling the motherboard's sound card- probably a bit worse.
I ripped to the internal hard drive instead of the remote hard drive.
I tried the Windows Media player a bit louder but still a difference.
post #16 of 18 Old 11-19-2010, 06:28 AM
dknightd's Avatar
That is strange. Bits are bits - you wouldn't think it would matter if they were read from a CD or read from a HD. Maybe Windows is treating them differently. I'm a Mac guy, but believe windows xp uses something call k-mixer. Google it - my understanding is you want to try and bypass it for best sound.
dknightd is offline
post #17 of 18 Old 11-19-2010, 07:01 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Try to use ASIO mode. If your sound card does not support it natively, install asio4all driver.
ap1 is offline
post #18 of 18 Old 11-19-2010, 09:02 PM - Thread Starter
Quoted: 13 Post(s)
Uninstalled & reinstalled iTunes it has been sounding good all night
