Snap Crackle and Pop - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-22-2010, 09:02 PM - Thread Starter
ddoremus's Avatar
So it has been a while since I invested in new gear. Just moved and finally connected ps3 to LED TV and from there had to go analog to my 15+ year old JVC surround sound amp. I have Cerwin Vega speakers (also 15 + years old).
When I have it all connected now I am getting buzzing, popping and crackling. I was not getting this prior to moving and having this new setup. Old setup was all analog and sounded great.
I am trying to troubleshoot the issue. I seem to only be getting the extra noise when I run this setup. FM radio output sounds good. I am using the phono input on the amp.
Seems like this is an issue due to routing through the TV. Am I right? Is using the phono input an issue? Anything else I should be considering?
Is this just going to be an issue unless I upgrade my amp?
Thanks to any help or thoughts.
ddoremus is offline
post #2 of 3 Old 11-22-2010, 09:19 PM
Gizmologist's Avatar
Liked: 31
The PHONO input is to be used for ONLY that. A turntable. Any other signal is waaaaaay too hot and you will get tons of distortion etc. Exactly what you are hearing.
Gizmologist is offline
post #3 of 3 Old 11-24-2010, 11:58 AM
LanceBeasley's Avatar
Yea, the phono input has amplification and RIAA equalization that is extremely specific to phonograph players.
LanceBeasley is offline
