Turntable Repair+Setup in Philadelphia / South Jersey? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-22-2010, 05:05 PM - Thread Starter
BrewDrinkRepeat's Avatar
My turntable (Technics SL-1600 mk1) has hardwired cables that are shot... I need to get new ones installed, or perhaps have jacks installed instead so I can use any of the extra interconnects I have lying around.
I'd love to have it set up properly as well, I have no idea how to do that. (The manual is long gone.)
Any recommendations for a reliable, reasonably-priced shop in the Philadelphia / South Jersey area? I don't play a ton of vinyl, so I don't want to spend an arm and a leg (and I don't want someone intent trying to sell me $100 cables, either).
BrewDrinkRepeat is offline
post #2 of 6 Old 12-23-2010, 07:04 AM
Ratman's Avatar
Quoted: 1271 Post(s)
Liked: 1022
http://www.bcelectron.com/repair_typ...er_repair.html
Also, check "yellow pages" for stereo service/repair shops locally and give 'em a call.
Try the Geek Squad (at Best Buy)?
You may be able to get manual here:
http://www.vinylengine.com/library/t.../sl-1600.shtml
Ratman is online now
post #3 of 6 Old 12-24-2010, 11:00 AM - Thread Starter
Aweome, thanks... have you used BC before?
post #4 of 6 Old 12-24-2010, 11:46 AM
Ratman's Avatar
Liked: 1022
No. I'd either attempt to fix it myself or buy a new turntable.
post #5 of 6 Old 01-25-2016, 09:31 AM
Liked: 0
I know this is an old thread but for possible future needs,....check out Analog Restorations. They are located about 15 miles from you. They actually remove the RCA cables and replace them with gold RCA jacks on the rear panel. It's a lot cleaner looking and allows you to use your own interconnects. you're not forced into $100 cables that "make a huge difference".
Aside from there website, you can also check them out on Facebook at Analog Restorations.
ID:	1208930   Click image for larger version
ID:	1208938   Click image for larger version
crenasman is offline
post #6 of 6 Old 01-25-2016, 09:32 AM
Liked: 0
They are also remarkable reasonable in pricing.
