Spdif audio output to Coaxial audio or optical audio input - AVS Forum | Home Theater Discussions And Reviews
post #1 of 36 Old 12-29-2010, 03:57 PM - Thread Starter
rocketman70433's Avatar
TV has spdif audio output, and I need to connect it to a theater in box.
The box has a coaxial audio & an optical audio input.
Is there any way I can connect them? What kind of cable do I need and does price matter?
rocketman70433 is offline
post #2 of 36 Old 12-29-2010, 04:04 PM
Ratman's Avatar
Quoted: 1276 Post(s)
Liked: 1024
The TV probably has an optical (Toslink) output. Use that ...
You can get an inexpensive optical cable from:
http://www.monoprice.com/products/su...02&cp_id=10229
Ratman is offline
post #3 of 36 Old 12-29-2010, 04:11 PM - Thread Starter
How about this? I know it'll cost a lot more, but Im supposed to get her hooked up on Saturday.
http://www.bestbuy.com/site/AudioQue...link&cp=1&lp=1
post #4 of 36 Old 12-29-2010, 04:16 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
S/PDIF is the protocol being used, not the type of cable. Optical and digital coax connections both use S/PDIF. Get whichever type your TV has, most likely optical.
$40 is way too much to spend on a cable. Get it from a place like monoprice for just a couple of dollars. Same quality, much cheaper price.
BIslander is offline
post #5 of 36 Old 12-29-2010, 04:29 PM - Thread Starter
So an optical cable is an optical cable? What matters is what each end of the cable is connecting to?
post #6 of 36 Old 12-29-2010, 04:32 PM
Tulpa's Avatar
Liked: 61
Yes, they're the same. Only difference is the outrageous markup on Best Buy's cable.
Monoprice delivers pretty fast depending on where you live, but if it HAS to be hooked up by Saturday, shop around a little. $40 for an optical is INSANE. I know I've found them for half that at stores, although I still would wait for Monoprice.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #7 of 36 Old 12-29-2010, 04:34 PM
mgkdragn's Avatar
Quoted: 1705 Post(s)
Liked: 1983
Yep .. in a pinch, I've even used a regular RCA (I'm not suggesting you do) .. Radio Shack would likely be cheaper on a TOSLINK than BB .. hell, I've seen them at Walmart ..
Uncle Willie
Oddball: Why don't you knock it off with them negative waves? Why don't you dig how beautiful it is out here? Why don't you say something righteous and hopeful for a change?
mgkdragn is offline
post #8 of 36 Old 12-29-2010, 04:38 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
A regular RCA can be used instead of digital coax, but not optical.
post #9 of 36 Old 12-29-2010, 04:39 PM - Thread Starter
So if I walk into radio shack, I'm going to ask the clerk for an optical cable? He'll know what I need based on that?
post #10 of 36 Old 12-29-2010, 04:40 PM
mgkdragn's Avatar
Liked: 1983
Yes, I should have clarified that .. thanks .. don't need someone attempting to shove an RCA in a TOSLINK hole .. not a pretty sight ..
Uncle Willie
mgkdragn is offline
post #11 of 36 Old 12-29-2010, 04:41 PM
mgkdragn's Avatar
Liked: 1983
If he/she does not know, the World would be a sadder place ..
Uncle Willie
mgkdragn is offline
post #12 of 36 Old 12-29-2010, 04:42 PM
Kal Rubinson's Avatar
Quoted: 673 Post(s)
Liked: 460
He should but better to call it a digital audio optical cable or a TOSlink cable.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #13 of 36 Old 12-29-2010, 04:49 PM
Tulpa's Avatar
Liked: 61
Make sure it has this type of end:
The connector might look slightly different, depending on brand, and there should be a little plastic cap on the end that you remove prior to connecting.
Tulpa is offline
post #14 of 36 Old 12-29-2010, 08:39 PM
DonH50's Avatar
Quoted: 1792 Post(s)
Liked: 1325
And, do NOT look into the pretty red light!
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #15 of 36 Old 12-30-2010, 07:43 AM
razr67's Avatar
Why not? It's a red LED, it won't hurt you.
razr67 is offline
post #16 of 36 Old 12-30-2010, 09:10 AM - Thread Starter
I dont know if the tv is optical or coax, won't know until I see the back of the TV on saturday.
If it isn't optical (meaning TOS link, right?), what else can I use to connect the 2? Someone mentioned something about using RCA to connect coax.
post #17 of 36 Old 12-30-2010, 09:14 AM - Thread Starter
This might help
My friend has a Sony DAV-HDX285 theater in box.
Its inputs include:
* Analog Audio Input(s) : 1 (Rear-RCA) & 1 (Front-Mini Jack)
* Coaxial Audio Digital Input(s) : 1 (Rear)
* Component Video (Y/Pb/Pr) Output(s) : 1 (Rear)
* D.C.A.C. (Auto Calibration) : Yes
* Digital Media Port (Input) : Yes (TDM-iP20 included)
* Headphone Jack : 1 (Front- Mini Jack 3.5mm)
* Optical Audio Input(s) : 1 Rear
* Optical Audio Input(s) : 1 (Rear)
* Speaker Terminal : 6 DAV Clips (Rear- 2 Front/ 2 Surround/ 1 Center/ 1 Sub)
Her TV is a Visio SV420XVT1A
Those outputs include:
* 1 x Composite video/audio input ( RCA phono x 3 ) - Side
* 1 x Component video input ( RCA phono x 3 ) - Side
* 2 x HDMI ( 19 pin HDMI Type A ) - Side
* 2 x HDMI ( 19 pin HDMI Type A ) - Rear
* 3 x Audio line-in ( RCA phono x 2 ) - Rear
* 1 x Composite video input ( RCA phono ) - Rear
* 1 x Component video input ( RCA phono x 3 ) - Rear
* 1 x S-Video input ( 4 pin mini-DIN ) - Rear
* 1 x VGA input ( 15 pin HD D-Sub (HD-15) ) - Rear
* 1 x Audio line-in ( RCA phono x 2 ) - Rear
* 1 x SPDIF output ( TOSLINK ) - Rear
So I'm assuming that I have to use the TOS cable that people already suggested.
post #18 of 36 Old 12-30-2010, 09:22 AM
whoaru99's Avatar
Liked: 69
Not saying TVs with coaxial digital output don't exist, but every one I've seen so far has optical/TOSlink output.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
post #19 of 36 Old 12-30-2010, 09:41 AM
Tulpa's Avatar
Liked: 61
This might help
Its inputs include:
Yep. Connect the two bolded items with the cheapest optical cable you can find.
Tulpa is offline
post #20 of 36 Old 12-31-2010, 11:50 AM
3toSea's Avatar
I have a similiar question and thought I'd jump in on this thread. I need to connect the TOSlink optical out on my TV to the TOSlink optical in on my receiver. However, the TV is in the family room and the receiver is in another room in a rack.
This connection will hopefully solve the only gap in my A/V setup which is when I am streaming netflix via the TV internet connection, right now I can only use the TV speakers.
I have extra UTP and Coax runs - does anyone make a coverter from TOSlink to/from coax or UTP? I was hopeful that the TV would have a digital coax output but that was quickly dashed.
3toSea is offline
post #21 of 36 Old 12-31-2010, 11:57 AM
mgkdragn's Avatar
Liked: 1983
TOSLINK is optical / Coax is wire .. no way to make an adapter
Uncle Willie
mgkdragn is offline
post #22 of 36 Old 12-31-2010, 12:13 PM
Ratman's Avatar
Liked: 1024
I could be wrong, but I don't think NetFlix supports DD5.1 via streaming. So, no reason to use optical.
If you have two coax runs, just use F to RCA adapters for analog audio from TV to rack.
Ratman is offline
post #23 of 36 Old 12-31-2010, 12:15 PM
Ratman's Avatar
Liked: 1024
There are adapters to convert Toslink to digital coax:
Or....
Digital coax to Toslink:
Ratman is offline
post #24 of 36 Old 12-31-2010, 12:22 PM
Tulpa's Avatar
Liked: 61
Some watch-it-now titles do, but I think the list is limited.
Tulpa is offline
post #25 of 36 Old 12-31-2010, 01:11 PM
Ratman's Avatar
Liked: 1024
And again... I could be wrong, but perhaps that's only possible when using a PS3 as the interface.
Ratman is offline
post #26 of 36 Old 12-31-2010, 01:45 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
It's only the PS3 now. But, it seems likely to expand to other equipment going forward.
post #27 of 36 Old 12-31-2010, 01:52 PM
Tulpa's Avatar
Liked: 61
I can't see any reason why they wouldn't go forward with it. It just happens to be in its infancy right now.
Tulpa is offline
post #28 of 36 Old 12-31-2010, 01:54 PM
whoaru99's Avatar
Liked: 69
I get HD Netflix streaming on a Panny BD60, but I have yet to get one in DD5.1.
whoaru99 is offline
post #29 of 36 Old 12-31-2010, 02:39 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Netflix added DD+ as a firmware update for the PS3 in the fall. There have been no announcements regarding other devices. But, you have to think others will get it, too.
post #30 of 36 Old 12-31-2010, 02:48 PM
Ratman's Avatar
Liked: 1024
Other than bandwidth and a plethora of firmware updates to a large number of existing Netflix enabled devices, I agree, no reason.
Heck... they don't even make (but a few) TV's with DD5.1 passthrough.
Ratman is offline
