In Ceiling Center vs Center on a Entertainment Center - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-30-2010, 07:44 PM - Thread Starter
mxpx5678's Avatar
Liked: 24
I currently have a Niles Audio CM730 center channel in my ceiling as part of a 5.1 system. (Niles also as L/R and mono price as the rears) being driven by denon AVR591.
I am curious if i would be better off putting a new center channel speaker (would spend about 200) on my entertainment center instead of using the in ceiling. I sometimes feel like the in ceiling sounds too weak.
This would also require me to wall mount my tv but that isnt a big deal.
Thanks for any advice!
mxpx5678 is offline
post #2 of 7 Old 12-30-2010, 09:15 PM
CharlesJ's Avatar
Quoted: 425 Post(s)
Liked: 252
Ceiling speakers are OK for casual background music. It is a terrible place for a center or for any 5.1 surround speakers.
CharlesJ is offline
post #3 of 7 Old 12-30-2010, 09:44 PM
Magnefied's Avatar
What Charles said. The ceiling is a last resort when there are no other options. Rears in a 7.1 system are probably the most tolerant of ceiling mounting. The center is probably the least tolerant if you're talking about movies. If video isn't that important to you and 2 channel music is the main goal, then maybe a ceiling mounted center channel can be tolerated.
Magnefied is offline
post #4 of 7 Old 12-30-2010, 11:50 PM
stang323's Avatar
I would imagine ceiling center would be like someone talking to you but giving you their back, not as clear but you can hear them
stang323 is offline
post #5 of 7 Old 12-31-2010, 12:31 AM - Thread Starter
mxpx5678's Avatar
Liked: 24
Thanks for the help. I think I will move to a traditional center. The restworks pretty well in ceiling. Though I may eventually want floor standing fronts too. Now comes the hard part. Choosing a decent center....
mxpx5678 is offline
post #6 of 7 Old 12-31-2010, 08:56 PM
CharlesJ's Avatar
Quoted: 425 Post(s)
Liked: 252
Well, you should really plan ahead and use a center now but you should also use that companies left and right speakers later, not all mixed up.
And, if you do the center and others in the ceiling, you will have a funny response.
CharlesJ is offline
post #7 of 7 Old 12-31-2010, 08:59 PM - Thread Starter
mxpx5678's Avatar
Liked: 24
Yeah I think that is the plan. I about to pull the trigger on a bic center and sub.
Then I could get their matching left and right speaker. But still use the inceiling for the rears.
mxpx5678 is offline
