FM Transmitter and annoying neighbors - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 01-06-2011, 10:47 PM - Thread Starter
icannotpark's Avatar
Hey Guys,
Im new here, so bare with me. I have these annoying neighbors that blast there music all the time. We have asked them nicely to turn it down, but they continue to have the bass turned up. Its getting real bad. I had an idea. We live in a duplex, so we share the same wall and i can tell that the radio is on the same wall. I can hear the music clear enough to hear what station they are listening too. Here's my question, is it possible to get a powerful enough FM transmitter to over take the station that they listen too? If its possible, should I play crappy music that they dont like through there radio, or have a message?
Cheers
Josh
icannotpark is offline
post #2 of 18 Old 01-07-2011, 12:05 AM
Colm's Avatar
Liked: 94
Sure, easy and cheap. Problem is that it is illegal to do what you want to do. Find another way to deal with it.
Colm is offline
post #3 of 18 Old 01-07-2011, 01:09 AM
DocS2011's Avatar
DocS2011 is offline
post #4 of 18 Old 01-07-2011, 01:17 AM
DocS2011's Avatar
I also found this:
www[dot]wholehousefmtransmitter[dot]com
DocS2011 is offline
post #5 of 18 Old 01-07-2011, 05:11 AM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
Why not outrock them? Buy a massive sub, and everytime they blast their music, rock your subs harder. A couple proper subs from Elemental Designs will shake your entire duplex.
shadyJ is offline
post #6 of 18 Old 01-07-2011, 07:49 AM
Gizmologist's Avatar
Liked: 31
Bagpipes in the middle of the night playing "Scotland The Brave" on a loop.
Gizmologist is offline
post #7 of 18 Old 01-07-2011, 08:57 AM - Thread Starter
haha, thanks guys. I have tried to out rock them. I used to play bass in a band, I set up my Peavey amp against the wall and played of an hour or so. It didnt phase them. I dont care if it illegal at this point. If its legal to use in my one home and it ends up over powering their station... oh well.
post #8 of 18 Old 01-07-2011, 09:46 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
If you take over FM, they will switch to Pandora or other Internet radio. Then you need to mount DoS attack on them. It will never ends.
Check your town ordinances about noise, and if you find something useful, invite police to enforce it.
ap1 is offline
post #9 of 18 Old 01-07-2011, 11:11 AM
HawaiianHDaddict's Avatar
If you're in a rental unit then call the landlord and inform him of the problem. If the duplex is part of a homeowners association then check the association rules for noise regulations and call the association. And like ap1 suggested, check your town ordinances to see if you can get the police involved.
HawaiianHDaddict is offline
post #10 of 18 Old 01-07-2011, 11:17 AM
whoaru99's Avatar
Liked: 69
If you are the only one complaining it's just a "he said, she said" situation and both you and the neighbor are (presumably) paying your rent so there is no strong incentive for the landlord to take a side. So, unless you can enlist the help of neighbors etc. to raise the same concern, frankly, you might be the one viewed as the problem.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
post #11 of 18 Old 01-07-2011, 11:23 AM
Tulpa's Avatar
Liked: 61
What is it about this forum? Every few months I see someone who has a problem with their neighbors and they want to go for the nuclear option.
One dude was CONVINCED his neighbor was sending signals (kind of like what the OP wants to do) to screw with his equipment.
Can't we all just get along?
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #12 of 18 Old 01-07-2011, 11:28 AM
whoaru99's Avatar
Liked: 69
Sure, as long as the only thing that's shaking my bed is my GF and I.
whoaru99 is offline
post #13 of 18 Old 01-07-2011, 12:04 PM
Ratman's Avatar
Quoted: 1276 Post(s)
Liked: 1024
IMO... don't buy/rent a condo, townhouse, apartment or duplex if "noise" may be an issue for either party(s).
There are contractors that you can consult to reduce noise between "shared wall" dwellings.
Ratman is offline
post #14 of 18 Old 01-07-2011, 07:49 PM
Magnefied's Avatar
Pair of Velodyne DD18 subs against the common wall, one filthy gangsta rap CD in a CD player set to repeat, turn it up to 11, go to Cancun for a week.
Magnefied is offline
post #15 of 18 Old 01-08-2011, 10:09 AM
whoaru99's Avatar
Liked: 69
I see you had a water leak in your house while you were away. Too bad...hopefully nothing got ruined.
whoaru99 is offline
post #16 of 18 Old 02-14-2013, 06:12 AM
Ratman's Avatar
Liked: 1024
(and it's spelled "BASS")
Ratman is offline
post #17 of 18 Old 02-14-2013, 06:38 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
I heard that ED was not standing up for itself any more.
arnyk is offline
post #18 of 18 Old 02-14-2013, 06:41 AM
JD in NJ's Avatar
Liked: 36
*rimshot*
JD in NJ is offline
