HDMI vs. Fiber optic cables - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-14-2011, 12:14 AM - Thread Starter
CMBoardman's Avatar
For my home theatre system, I was wondering what would be better, if there's going to be a difference, in using just an hdmi cable or using both hdmi and fiber optic. What would be the difference in using a M1000 monster hdmi cable alone compared to using just some slightly cheaper hdmi cable with a M1000 fiber optic cable. I'm still very new to hd sound and I'm not sure what the difference is because the hdmi cable still outputs hd sound, right? But, then I looked at the M1000 toslink and the price was considerably higher than the hdmi.....help?
CMBoardman is offline
post #2 of 4 Old 01-14-2011, 12:31 AM
Colm's Avatar
Liked: 94
Toslink doesn't support the HD audio formats, HDMI does. Otherwise, they will sound the same.
Colm is offline
post #3 of 4 Old 01-14-2011, 06:08 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
There's no need to buy expensive cables, which is just a waste of money. You can buy excellent cables at reasonable prices from forum sponsor monoprice.com.
HDMI would be preferable. It's a single cable for both audio and video and it supports lossless audio and multichannel PCM, both of which are beyond the capabilities of optical.
BIslander is offline
post #4 of 4 Old 01-14-2011, 01:14 PM
Ethan Winer's Avatar
Quoted: 264 Post(s)
Liked: 359
Optical or RCA digital is potentially better for audio than HDMI which tends to have much more jitter. Usually jitter is a non-issue with digital audio, regardless of what you read in the hi-fi magazines. But the jitter from HDMI audio can be ten times worse, bordering on being just barely audible.
--Ethan
Ethan Winer is offline
