For all the mega buck cable devotees - Page 23 - AVS Forum | Home Theater Discussions And Reviews
post #661 of 668 Old 02-11-2011, 05:25 PM
CharlesJ's Avatar
Quoted: 425 Post(s)
Liked: 253
.. Audio myths are too boring for most!
Limited audience
Originally Posted by CEDUPZ View Post
.... Isn't Canada owned by the U.S. anyway?
In time, in time.
CharlesJ is offline
post #662 of 668 Old 02-12-2011, 09:01 AM
whoaru99's Avatar
Liked: 69
Cheater plugs are also a NEC violation. Read the code, understand the code, it matters.
Code? We don't need no stinking code...
Also, I would argue they are not a violation in the situations I mentioned above. Certainly it can't be a violation to not use an equipment ground that isn't being used by the equipment.
Sorry, I couldn't resist. I just don't get off anymore on the blind rage rants.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
post #663 of 668 Old 03-02-2011, 06:30 PM
scud133's Avatar
Originally Posted by Gizmologist View Post
The same equipment is used IN recording studios, its just harnessed in a permanent rack. BTW, ever see the interconnect cables used by guitarists for the stomp boxes? about 5.00 each and these boxes use wall wart power supplies of -OMG- 9 volt batteries.
Nobody is arguing the acoustics from the FOH (front of house) systems are not quite as "revealing" (love THAT term, hahahaha) as a home system HOWEVER, you need to learn HOW that concert audio is recorded. Each mic and or instrument pickup is fed via a signal splitter (usually a 1x3 transformer in some configuration) to the FOH mix desk, a second mix desk- on or close to the stage -that handles the monitor mix for the performers and a 3rd that is the recording system feed. This can be a multi-track recording system that will take the tracks and be used for a studio mix down or in some cases, field mixed then and there in a production truck into a stereo recording.
Keyboards, drum machines, and every kind of electronic instrument and effects system uses the same inexpensive and frequently unbalanced interconnects. Ever hear of Direct Boxes (D.I.)? These are usually passive but sometimes active unbalanced to balanced interfaces to directly feed an instrument into the mix desk. BTW, the next time you see a electronic keyboard or drum machine, look at the power cable; standard off-the-shelf IEC AC cables plugged into stage boxes
Studios also use passive patch bays for analog signals and processors. The wiring for these patch bays is quite dense and snugly bundled as all proper permanent racks enclosures are.
You really need to go to a studio in person and learn first hand what equipment and wiring is used in a studio environment. You will not find anything exotic, regardless of what some claim since they too have never been in the wiring and control area of a studio.
what if you're so cheap you consider Mogami "exotic" ??
scud133 is offline
post #664 of 668 Old 10-01-2012, 03:58 PM
bluemark81's Avatar
Maybe this has already been discussed so my apologies if so, but can anyone explain to me how Audioquest can claim to apply 72v to the wires in their DBS systems using a couple of 1.5v batteries?
Click here for pic of my 7.1 home theater system and here for pic of S2 surround wall mounting.
Click here for pic of my 2 channel system.
bluemark81 is offline
post #665 of 668 Old 10-01-2012, 04:20 PM
WarHorse's Avatar
Magic.
WarHorse is offline
post #666 of 668 Old 10-01-2012, 07:24 PM
A9X-308's Avatar
Quoted: 1393 Post(s)
Liked: 1039
Most likely a switching inverter.
“If you want to be funny these days, tell the truth.” Bill Leak, 2016
Vale Bill. Sadly, the master has gone.
A9X-308 is offline
post #667 of 668 Old 10-01-2012, 07:43 PM
bluemark81's Avatar
....or nuclear fusion.
post #668 of 668 Old 10-01-2012, 09:49 PM
A9X-308's Avatar
Liked: 1039
The lack of radiation shielding would also account for the diminished mental faculty of the people who buy and use them.
A9X-308 is offline
