Placement advice - AVS Forum | Home Theater Discussions And Reviews
Old 02-11-2011, 07:40 PM - Thread Starter
Jrlane's Avatar
I realize this basement needs to be finished but its out of the question, its not my home. So... id like to do what i can for the time being. I am all for buying acoustic treatments if needed, but if i can do some cheap things like a big blanket or some material to block off an are that would be great. The white walls are cement, and the wall the speakers are in front of is thick insulation under a plastic cover so to speak. I also have a boat load of berber carpet i can put wherever.
Jrlane is offline
Old 02-12-2011, 11:48 AM
Ethan Winer's Avatar
Quoted: 264 Post(s)
Liked: 359
I don't see any specific questions, but this will get you started:
Acoustic Basics
How to set up a room
--Ethan
Ethan Winer is offline
Old 02-12-2011, 01:30 PM - Thread Starter
Jrlane's Avatar
Questions are:
1. Where to place speakers?
2. What do you think about blocking portions off with a thick curtain?
Jrlane is offline
Old 02-13-2011, 11:42 AM
Quoted: 264 Post(s)
Liked: 359
^^^ Both of those questions are addressed in the two short articles I linked. There's only one "best" way to orient a room, and curtains are not useful for acoustic treatment or sound blocking.
--Ethan
Old 02-13-2011, 07:48 PM - Thread Starter
Jrlane's Avatar
The article is about rectangular rooms. Mine is obviously not, and has complex areas like the stairs and heaters. I just want to know what corner to put them in.
Jrlane is offline
Old 02-14-2011, 10:02 AM
Quoted: 264 Post(s)
Liked: 359
Without a floor plan, just by those photos, I can't tell much about the shape of your space. But the basic principles of symmetry and treatment apply. With a simple floor plan drawing I could be more specific. The main treatment goals for all rooms are bass trapping and reflection absorption.
--Ethan
