Video or Audio but NOT Both - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-19-2011, 10:36 PM - Thread Starter
mcantrell's Avatar
Hey all, longtime lurker...first time poster
here's my setup
TX-SR508
Sony 55" LCD
HTPC
Acoustimass 16
the HTPC has a DVI Out and Optical Audio Out
the TX-SR508 is connected to the HTPC using an audio Toslink Cable and an HDMI to DVI Cable. The TV is connected by HDMI to the TX-SR508
The cables and connections are verified as working and functional
the source is verified as working (audio card/video card)
The Issue:
with the source playing a sample (movie music whatever) I'm able to either have video only...unless i disconnect the hdmi from the HTPC...then i lose picture and gain audio.
This is a brand new setup (less than a month) and it was working for the first 2 weeks without any configuration...and now for whatever reason i feel as though a setting must be "checked" or "unchecked" however after "playing" with it i'm in no better shape than when i started.
I've assigned corresponding HDMI ports to the correct Optic Ports...i've rotated from all of them...with the situation getting no better than "one or the other"
I have changed optic ports as well and of course reassigned that port to the new hdmi port.
as a last resort i consulted the owner's manual...however nothing is clearly stated as to how to set up what i need in this situation
the result i'm looking to achieve is to use the optic port as my audio and the hdmi for my video...at the same time.
if anyone knows how to achieve this or even have an idea about how to do so I would be greatly appreciative thank you.
mcantrell is offline
post #2 of 5 Old 02-19-2011, 11:00 PM
amirm's Avatar
Quoted: 1334 Post(s)
Liked: 740
Sounds like you have already configured it the right way. It is usually done in HDMI menu for that input, telling it the audio comes from Toslink, not HDMI.
If that is what you have done and still doesn't work, then there is something broken with the processor. Do you have another source with Toslink out to test with?
amirm is offline
post #3 of 5 Old 02-20-2011, 07:18 AM
JChin's Avatar
Quoted: 367 Post(s)
Liked: 210
Hi mcantrell, with HDMI Input and Digital Audio Input menu assigned correctly (to the same Input Selector name for your HTPC). Try selecting your input source, press "Receiver" then "Audio" button on the remote and select OPT under "Audio Selector".
JChin is offline
post #4 of 5 Old 02-20-2011, 09:25 AM - Thread Starter
mcantrell's Avatar
OK This is what i have selected under the "HDMI Setup"
Audio TV Out "off" (i do not have an audio out to TV as i'm not using my tv speakers)
Lipsync "disable"
HDMI Control 'off"
Audio Return Ch "auto"
Power Control "off"
TV Control "Off"
post #5 of 5 Old 02-20-2011, 09:40 AM
JChin's Avatar
Quoted: 367 Post(s)
Liked: 210
^^^ none the above settings is going to select optical audio over HDMI audio.
JChin is offline
