Any alternate product just like SONOS? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 12-23-2011, 12:45 PM
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2826
Airport Express, 65.00 a zone. Apad , laptop , itouch , iphone, anything can control it. I am using two zones now. My laptop is the hub to the whole thing
yup, got an old laptop that is pretty much dead but stays on all the time holding my Library and always available, it goes to sleep all day while im at work, I simply press the wake button and tunes comes right up and im bumpin in less than a minute... I would entertain a better way to hold my itunes library that the network could see at all times...other than my phone
beastaudio is offline
Old 12-23-2011, 03:09 PM
ubermusik's Avatar
I think eventually we will see products come out that support "iTunes in the Cloud" and "iTunes Match" so that computers wont have to be on in order to access the library in whole house audio solutions. I suppose it all depends on if Apple will license an API for the Cloud/Match services and/or if there will be enough interest for it to be reverse engineered.
ubermusik is offline
Old 01-02-2012, 07:58 PM
DaHuskers's Avatar
Great Thread. I'm looking for the same thing, but it appears that nothing equal or better than Sonos is available yet. The mesh network it runs on appears to be much more reliable than a wifi based system, but the price is less impressive than the product. What really gets me is the "Connect" and that's the first piece I'd need. I've waiting for an alternative, perhaps Windows 8 may offer a solution, but it looks like I may have to bit the bullet and go with Sonos.
DaHuskers is offline
Old 01-02-2012, 11:01 PM
ubermusik's Avatar
The mesh network [Sonos] runs on appears to be much more reliable than a wifi based system
The mesh topography network that Sonos uses is nice for certain installation scenarios, but it doesn't necessarily make it any more reliable than a good Wi-Fi network. In fact, if setup correctly a standard 802.11 Wi-Fi network can be just as reliable as a Sonos network and have the added benefit of actually providing network connectivity for all devices other than just the Sonos hardware.
Here is why:
A Sonos mesh network is just a hidden 802.11n wireless network that utilizes IEEE 802.1D Spanning Tree (STP) for its mesh bridging properties. The reason you can't see the network is because it doesn't broadcast an SSID and its encrypted so non-Sonos devices can't connect to it. It runs over the 2.4Ghz and 5GHZ bands just like normal modern MIMO routers do. And because it runs on the 2.4 and 5Ghz bands, its just as susceptible to interference from other Wi-Fi networks and bandwidth limits. So using a Sonos system in a crowded apartment complex with many other networks isn't going to guarantee a more reliable connection. Read about Shannon's Law for a technical explanation as to why.
There are several ways that one can setup a robust wireless network just as reliable as the Sonos mesh network but that is not limited to providing coverage to just Sonos devices:
1. Setup a wireless network with multiple access points. Instead of having the router the only device distributing a wireless network, access points can be plugged into the network that extend the network's wireless range.
2. Setup a Wireless Distribution System (WDS) network. This is where multiple wireless routers or devices interconnect wirelessly with each other to extend the range of the network. Using an Apple Airport Extreme in combination with Airport Expresses makes setting up a WDS network very easy (plus each Airport Express is also an Airplay device!).
Nethawk likes this.
Old 01-06-2012, 01:38 PM
Transplanted99's Avatar
Originally Posted by übermusik View Post
...There are several ways that one can setup a robust wireless network just as reliable as the Sonos mesh network but that is not limited to providing coverage to just Sonos devices:
Very nice writeup on the technical aspects of the wireless.
But this illustrates one nice feature of Sono...simplicity of setup...for most consumers, hands down it beats having to set up and support a network as described above.
Also, I understand that one can connect to Sonos through its ethernet port to take advantage of its wireless functionality. Perhaps one can add an access point (Airport Express?) to that same port for internet wireless access.
Agree. Disappointingly, Apple does not do this today (maybe someday as you mention - fingers crossed). As I understand it, multi-zone for Apple products requires multiple instances of iTunes running, or a third party application running on one or more computers...not simple.
I wish there was real competition that has what Sonos has, as they do charge a premium. Sonos is the only "close-to-reasonably-priced" solution that is simple, allowing for simultaneous, unique streams to muliple zones.
Transplanted99 is offline
Old 01-06-2012, 02:08 PM
Jinjuku's Avatar
Quoted: 58 Post(s)
Liked: 148
Originally Posted by Transplanted99 View Post
Yes...that is a very workable solution and there are many folks who like the Squeezebox.
For about the same price ($400-$500) per zone (or less with Sonos Play 3), the Sonos system has the added benefit of using it's own wireless network. Don't underestimate this, as it is the primary area where folks have had serious trouble with the setup and performance of alternative products to Sonos. Sonos is as close to plug and play as you can get on this. Read reviews at Amazon before you buy alternatives.
Throw in another Wireless N Multipath for $60, give it a unique SSID and put it on it's own channel (if you get a lot of collisions with the other AP, but doubtful). Back haul an Ethernet cable to the switch and put all your wireless streamers on it.
Heck if you wanted to get fancy you could put it on it's own subnet tied into a second NIC on the main computer.
An audiophile likes to talk about how much they spent and how good it sounds.
A DIY'er likes to talk about how little they spent and how good it sounds.
Jinjuku is offline
Old 01-07-2012, 01:48 PM
ubermusik's Avatar
Hmm... I'm going to have to try this. That would be an interesting concept to be able use Sonos hardware to create/extend a useable network.
Yeah Apple does not have a truly useable multi-zone setup. There is no UI for managing multiple simultaneous streams throughout the house and there will certainly never be an Apple supported way of playing from 3rd party sources like Pandora, Spotify, etc. all from the same interface. That would detract from their own music store and new iTunes Match service. Nor will Apple create software that works on Linux, Android, Zune, WP7 etc. Thats why I think we'll never see anything truly useable in this regard from Apple.
I'm going to have to disagree here. I think that some small app that's easy to install, is cross-platform, runs quietly in the background w/o hogging resources, automatically accesses online and local music sources, and doesn't require any configuration or interaction from the user, would be the ideal way of accessing multi-zone music on a home network.
Yeah I agree. That's why I'm really excited to see how the audio|acacia software turns out!
Old 01-21-2012, 02:31 PM
True, and can be done by your average techno geek, but the average joe will either not have the knowledge or not have the time to get up to speed enough to set up and support this. The premium Sonos is charging is for the simplicity and convenience...kind of like Apple's strategy.
Old 02-01-2013, 11:26 PM
Surfermsc123's Avatar
"There are several ways that one can setup a robust wireless network just as reliable as the Sonos mesh network but that is not limited to providing coverage to just Sonos devices:
2. Setup a Wireless Distribution System (WDS) network. This is where multiple wireless routers or devices interconnect wirelessly with each other to extend the range of the network. Using an Apple Airport Extreme in combination with Airport Expresses makes setting up a WDS network very easy (plus each Airport Express is also an Airplay device!)."
Wow. What a hassle..I'm sorry but who has time for all this? Certainly not me. So after reading this thread and others I purchased two Sono's Play 5's. They took 5-10 minutes to set up. The music quality is superb. The console is simple/easy to use from a computer or I-Phone. You can play any a music file from anywhere on the internet on the speakers. The music and radio options on Sono's are unlimited. I thought about purchasing the Apple Airport device so I could have more/larger speakers. However I was told by the Apple Store the device does not accept any music files not in the I-Tunes format and requires an I-Tunes account.
My only quip about Sono's is that it's not 100% wireless. It has a power cord. The speakers are not large so there is no reason they could not have installed a large lithium battery extension in the back. This would allow you to place the speakers in areas with no power cords.
Surfermsc123 is offline
Old 03-07-2013, 06:28 AM
avguy79's Avatar
avguy79 is offline
Old 03-08-2013, 02:03 AM
Nethawk's Avatar
Liked: 118
I'm an Apple and Sonos free home. It gets expensive when considering alternatives, and requires a good bit of nerdiness but the effort allows for a lot of flexibility (and better audio quality). I currently have 3 zones, will be setting up a 4th this weekend if speakers arrive despite a snowstorm. I use logitech squeezebox connected to each networked receiver, which allows simultaneous play in each zone. Everything is controlled from my Android phone and tablets.
I love my system, but it's not for everyone. I recommend Sonos much more frequently than I like.
Nethawk is offline
Old 05-31-2013, 05:22 PM
ocostich's Avatar
Here's the problems with Sonos vs Squeezebox
1) There is a limit on the size of the music library of, they claim, 65,000 tracks. However using tags can reduce that significantly, and Sonos has far more trouble with tags in general than Squeexebox.
2) Abysmal tech support. For Squeezebox the time to get a live support person is 3-4 minutes. For Sonos, it's closer to an hour, and then good luck getting a real answer. Even their email support takes days and you'll probably get a wrong answer. They seem far better at marketing than support
3) There is no provision to turn the device off. Typically these draw 5-10 watts so 50-100 kilowatts per year each. It's not a lot of money but it's hardly green, considering how many Sonos devices there are out there.
4) The android app for control is far better than Sonos'.
Here's' some advantages.
1) No server software on your computer, which is where Squeezebox has had most of its issues.
2) No reliance on mysqueezebox.com for internet based services.
3) You can still buy a new one.
Both have dropped the ball on building apps to use internet services like Spotify or MOG. Even when they have them they suck.
It also looks like Sonos is not interested in developing better technology, relying on just pushing what they've has for 5 years. Of course Logitech has abandoned Squeezebox or so it seems. Their are rumors of a new device from them other than the UE Smart Radio.
ocostich is offline
Old 05-31-2013, 07:58 PM
Nethawk's Avatar
Liked: 118
Nice list. One additional, and IMO huge advantage that Squeezebox has is third-party plugin development. I'm still using a third-party Spotify plugin over the mainstream one. Most often if there is an SDK and an interest, the turn around time for Squeezebox support is minimal. Off topic, but I'm hoping Google gets their act together and publishes something for Google Music so we see it in Squeezebox soon.
I do hope Logitech comes out with an alternative. I'm not a big fan of Logitech but the Squeezebox is/was a great product, it's extended my music listening significantly.
Nethawk is offline
Old 04-07-2015, 03:58 PM
Liked: 0
Reasonably Priced, Decent-Sounding Wireless?
Seems like this thread hasn't been active in awhile - I'm wondering if there have been any significant improvements in this area. I own some Sonos speakers and although the convenience is really nice, the sound quality is nothing compared to friends who have actual speakers. I'm always surprised how wonderful they sound when I hear them and my Sonos just don't seem to cut it.
I just want some nice, wireless sound - is that possible without spending several thousand dollars?
chrisdawk is offline
Old 04-07-2015, 04:48 PM
koturban's Avatar
Quoted: 225 Post(s)
Liked: 124
You could get Sonos Connect Amps and use your own speakers. Nuvo also makes a similar device. Neither one is cheap.
koturban is offline
Old 04-07-2015, 05:15 PM
Liked: 0
Thanks. I didn't know about those. It looks like they are $500 each? I assume I need one anywhere I want a pair of speakers?
Old 04-07-2015, 07:10 PM
koturban's Avatar
Quoted: 225 Post(s)
Liked: 124
Yes. Which basically puts you back into the same boat as the Sonos, where the costs add up quickly when you expand.
If you already have Sonos, I suggest you expand with some Connects or Connect Amps. Use them with your favorite speakers and move the Sonos Speakers to less important areas. Don't forget that you need an amp with the Connect.
I don't think Nuvo will have many advantages over Sonos, other than it can stream hi Res files, if that's your thing. I guess it'll depend on whether you simply want to cut your losses with Sonos.
koturban is offline
Old 04-07-2015, 08:58 PM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
1: small server with your content on it. Suggestion HP54L.
2: Wifi in the premises. Suggestion Netgear R7000/Asus RT86U
3: Small Android media player wherever you want it. Most have phone apps for control. See what's available locally.
4: JBL LSR305 active speakers. Smallest decent speakers I can think of (I own a pair).
This will require a small amount of effort to implement, but is considerably cheaper than a Sonos which is aimed at the Bose owner market.
A9X-308 is offline
Old 04-08-2015, 11:31 AM
Liked: 0
Thanks Koturban and A9X for all the info.
Are those JBL's wifi-enabled, or do they need to be wired to the server?
Old 04-08-2015, 01:02 PM
A9X-308's Avatar
Liked: 951
No, they are not wifi, and they would connect to the media player. The MP would connect to the server via your home wifi.
A9X-308 is offline
Old 04-08-2015, 03:46 PM
Liked: 0
Oh - gotcha. I misunderstood what you meant by media player. That sounds like a good solution - and you like those JBL's - can they fill a big room?
Old 04-08-2015, 08:38 PM
A9X-308's Avatar
Liked: 951
I have no idea what that means to you, so I can't answer. I use mine in a 3x5m bedroom. They were suggested as I thought you were looking for small-ish.
A9X-308 is offline
Old 04-11-2015, 08:05 PM
highfigh's Avatar
Quoted: 560 Post(s)
Liked: 172
Now that someone came out with something to compete with Sonos, look into the Denon HEOS Link or HEOS Amp- I only heard it in a large room, but it sounded better than SONOS.
highfigh is offline
Old 04-12-2015, 07:10 AM
A9X-308's Avatar
Liked: 951
^^ Post 48.
A9X-308 is offline
Old 04-23-2015, 11:46 AM
Liked: 0
[quote=IRJ;20625114]I use the logitech (slimdevices) Squeezebox equipment and am well satisfied with it.<br>
A friends loves his more expensive Sonos.<br>
What do you like about Squeezebox? Is there anything you like about it more than Sonos?
Old 05-24-2015, 12:17 AM
dkkruse's Avatar
What baffles me is that there are still no significant competitors to Sonos. Even Denon hasn't come up with a compelling competitor. If they (Denon) had made their HEOS able to connect to their Receivers, then I would be in yesterday.
dkkruse is offline
Old 05-24-2015, 05:57 AM
highfigh's Avatar
Quoted: 560 Post(s)
Liked: 172
Originally Posted by Surfermsc123 View Post
"My only quip about Sono's is that it's not 100% wireless. It has a power cord. The speakers are not large so there is no reason they could not have installed a large lithium battery extension in the back. This would allow you to place the speakers in areas with no power cords.
Batteries cost money and they want to hit price points. They discount to those who buy directly from them, but for an integrator who buys from distributors, there's no markup. This means it's pointless to sell Sonos without installation. I don't think a battery is necessary and for most people, portability isn't an issue. My gripe with the Sonos Play 1 and Play 3 is that they don't have a 12VDC-24VDC input jack. For those who want to use these as a replacement for their old surround speakers, this one detail means that almost nobody will use these for surround when the speakers were mounted close to the ceiling because an outlet is needed. If the Play 1 and 3 could use DC input, the speaker wires could have been used for power.
highfigh is offline
Old 05-24-2015, 06:04 AM
highfigh's Avatar
Quoted: 560 Post(s)
Liked: 172
By 'connect to their receivers", do you mean 'control the receiver's volume'? I'm not sure they see these systems as much more than a way to distribute music, as opposed to acting as a source on par with a BD, DVD, SACD or other sources. Yes, they work for that but most of the time, someone who's using an AV system is in the room, or in the area. Sonos and HEOS are made to enable operation over a much wider range of locations.
Sony receivers in the ES line turn on when Sonos starts up, which I found interesting.
I haven't heard anything about the lawsuit, lately. I wouldn't discount the possibility of new features in one or the other, in the future.
highfigh is offline
Old 04-12-2016, 02:22 PM
Liked: 0
Hey Highfigh, I am kind of in the boat since I want wireless surround for my TV, the SONOS so far has the best features...except being able to support the DTS. I like the Denon HEOS soundbar and I liked it in the store, however, you cant use the smaller speakers as rears...doesnt sound like it would be hard for this ability.
mmurphy21 is offline
Old 04-12-2016, 03:52 PM
highfigh's Avatar
Quoted: 560 Post(s)
Liked: 172
I just receivd an e-mail from Denon Heos regarding the new version-
"• New HS2 Models: HEOS1, HEOS3, HEOS5, HEOS7, HEOS Amp and HEOS Link
* The 4 speaker models will be available in both Black and White • High Resolution Audio Playback - 192kHz/24bit (multiple formats supported such as FLAC, WAV, ALAC)
* Watch for additional formats coming soon. • Built-in support for Bluetooth (Customers will no longer need the optional dongle) • Wireless AC spec for better wifi range (This is in addition to our current support for A,B,G and N) • A higher clock speed with 4x the memory of the current line. • Wireless surround technology (to be used with future products). • Plus more...
highfigh is offline
