Using energy time curve for acoustic analysis: developing a Home Theatre primer - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
Old 03-28-2012, 09:40 AM - Thread Starter
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
Originally Posted by krabapple View Post
Was this thread killed, or did it die of natural causes?
Like many acoustic threads here it took left turns, right turns, and U turns
Last month I added this in post#1, I don't feel this thread has run its full course of usefullness - yet.
[edit Feb-28-2012] Plan to re-boot this thread March/April 2012:
Come spring, when I re-do my 130" screen due to humidity induced warping of the screen, , I will totally remove all my existing side wall/ceiling panels and start from baseline of no treatments on the room
(besides my corner superchunks, which all have front facing reflective treatment on them)
I also will do the following:
-Pure reflective room baseline
-baseline of "the mirror tricK", as I did, with side wall 2" panels + 2" air gap
-Pure ETC approach and using 4" panels + 4" air gap at specific locations verified by ETC
-compare and make objective and subjective assessment
All above is being done utilizing porous absorbers.
As to dragonfyr's editing/removing his comments in specific posts for whatever reason....not sure if that happened or not.
mtbdudex is offline
Old 03-29-2012, 01:31 PM
krabapple's Avatar
Quoted: 382 Post(s)
Liked: 371
From what I can see, the thread's littered with replies to dragonfyr posts that no longer exist.
krabapple is offline
Old 03-29-2012, 01:35 PM
localhost127's Avatar
Quoted: 25 Post(s)
Liked: 58
maybe he went back to the 2D Flatland that is the frequency-domain and took all of his commentary with him!
localhost127 is offline
Old 03-29-2012, 05:22 PM - Thread Starter
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
I posted this inquiry to the forum operators in the Forum Operations Center area:
What happened to the majority of member "dragonfyr" posts from the thread Using energy time curve for acoustic analysis: developing a Home Theatre primer ?
Did the server go down and the back-up miss them?
He had 20-30 posts there with good info, now only 7 are left, search that thread based on member name:
http://www.avsforum.com/avs-vb/searc...rchid=21572958
If you do a search on the text "dragonfyr" you can see 19 quoted posts.
http://www.avsforum.com/avs-vb/searc...rchid=21572984
mtbdudex is offline
Old 03-30-2012, 01:30 AM
omholt's Avatar
So perhaps dragonfyr can again explain why don't need bandlimited ETC? This time I will make a copy of it.
omholt is offline
Old 03-30-2012, 08:18 AM - Thread Starter
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
Originally Posted by dragonfyr View Post
dragonfyr;
Did you delete your posts in this thread?
mtbdudex is offline
Old 04-15-2012, 03:57 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Back at this subject now and ... subscribed.
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
Old 11-18-2013, 05:07 PM
jim19611961's Avatar
Quoted: 449 Post(s)
Liked: 153
Originally Posted by localhost127 View Post
source: http://www.hifizine.com/2011/12/list...gy-time-curve/
ETC:
band-limited ETC:
so, with the band-limited ETC, you've not only produced more reflections, but they've also magically increased in gain as well ??
Originally Posted by Nyal Mellor View Post
Like I said previously and as you are no doubt aware an ETC (like an impulse response) is dominated by the highest frequency components. What gives you the idea that you would be able to compare an unfiltered ETC to a set of filtered ETCs?
Although this is referring to loudspeaker design it shows that there are multiple ways to analyze the energy decay - impulse response, ETC, filtered ETC, cumulative spectral decay. All have their place http://www.linkwitzlab.com/frontiers_2.htm
Also look here under part 4 absorber placement, you will see the use of band limited ETCs and the same rationale as I mention above for their usage http://www.etfacoustic.com/demoroom.all.html
Nyal, was a satisfactory explanation ever obtained for this question?
That is (bolded part), how are they to be compared?
My Room
My Music
Rega - Apollo, Rega - DAC, Goldpoint Passive, Classe CA-100, Crown XLS 1002, miniDSP
Jenzen Next
jim19611961 is offline
Old 11-18-2013, 05:10 PM
Nyal Mellor's Avatar
Quoted: 435 Post(s)
Liked: 312
Not that I remember. Of course a band filtered ETC will look different to an unfiltered ETC.
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is offline
Old 11-18-2013, 05:20 PM
Quoted: 449 Post(s)
Liked: 153
Right. But if a fullband ETC favors the high frequency content, when analyzing sliced ETC's, do we need to apply some form of curve to the bands to correct their relation to each other?
My Room
My Music
Jenzen Next
Old 11-18-2013, 05:28 PM
Quoted: 435 Post(s)
Liked: 312
No, it's just an unfiltered ETC is dominated by the highest frequency components.
Old 11-18-2013, 06:14 PM
Quoted: 449 Post(s)
Liked: 153
When comparing the full band ETC to separate bands of 500hz, 1K, 2K and 4K, the full band looks a lot like 4K plot to my eyes. To say the full band ETC favors the high stuff is an understatement I think.
My Room
My Music
Jenzen Next
Old 11-18-2013, 06:43 PM
Quoted: 435 Post(s)
Liked: 312
Farfield or nearfield? Try measuring nearfield on axis it should look a lot different
Old 11-18-2013, 07:16 PM
Quoted: 449 Post(s)
Liked: 153
Farfield (listening position,approx 8' from speakers).
My Room
My Music
Jenzen Next
Old 11-20-2013, 08:50 AM
Quoted: 449 Post(s)
Liked: 153
(200us smoothed) (Ignore line at top)
Black = Full range
Purple = 4K
Red = 500hz
An illustration of what I am seeing.
My Room
My Music
Jenzen Next
Old 11-20-2013, 11:24 AM
omholt's Avatar
The issue is resolved by using broadband absorption, redirection and diffusion.
omholt is offline
Old 11-20-2013, 11:33 AM
Quoted: 449 Post(s)
Liked: 153
I agree, in principle. I utilize all three of those in my room design. One of the biggest problems here is comparative data. No one posts sliced ETC's at their listening position.
My Room
My Music
Jenzen Next
Old 05-21-2014, 05:12 AM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
very helpful thread!
lbrown105 is offline
Old 11-04-2014, 01:39 PM
Quoted: 170 Post(s)
Liked: 64
Great Thread
Just read this whole thread , lots of good info but I still don't understand how to read the ETC results . All I see are squiggly lines . Someone should make a video on how to take measurements , how to understand those measurements , and how to apply acoustic treatments for those measurements.
HT-Eman is offline
Old 11-05-2014, 11:25 PM - Thread Starter
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
^^ HT-Eman
Hi and welcome to AVS forum, there are videos exactly like you desire on YouTube. Do a search and you will find them.
Have you read the REW help file?
Fantastic resources for various acoustic measurements.
Have you bought a measurement mic already? Which model?
I'm in hospital now recovering from RH hip replacement surgery, hard to search and paste via smartphone.
Here, took me a few minutes sitting in my hospital bed...this from Nyal Mellor.
More general how to take measurements:
Via Mikes brain/thumb interface, LLAP
|Tch0rT| likes this.
mtbdudex is offline
Old 11-06-2014, 02:59 AM
cinema mad's Avatar
Quoted: 18 Post(s)
Liked: 38
Mike,
Hope your recovery is swift mate, post Hip replacement surgery..
cinema mad is offline
Old 11-09-2014, 07:41 PM - Thread Starter
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
Originally Posted by cinema mad View Post
Mike,
Thx, I can't drive for 6 weeks, so lot's of re-hab and also reading AVS/other stuff.
I've got a few A/V projects planned to keep the brain active.
I'll also take a different viewpoint on this ETC thread and re-summarize, as my knowledge has grown since started it a few years back.
mtbdudex is offline
