Samsung BD-C6500 blu-ray and Yamaha V363 - front speakers only - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-22-2011, 09:00 PM - Thread Starter
richunger's Avatar
Hello everyone,
I've seen various threads where folks are only getting sound out of their front 2 speakers in a 5.1 setup. Usually, it appears to be the case that the source device is outputting PCM instead of bitstream. That may be the case for me as well, but I'm having trouble configuring the darn thing properly.
The receiver is a Yamaha V363. I've got the TV plugged in to the HDMI pass-through. The speakers test fine from the receiver's configuration menu (I can get test tones out of all the speakers that way).
The blu-ray player is a Samsung BD-C6500. The video connection is HDMI, and I have a toslink cable connected for the audio. When I go to the test tones in the Samsung's settings menu, the sound is all directed to the front 2 speakers.
I've tried various combinations of audio settings in the Samsung. Currently, they are set to:
Digital Output: Bitstream(Re-encode)
Other options here are Bitstream(Audiophile) and PCM. I've tried all 3.
PCM Downsampling: Off
Dynamic Range Control: Off
Downmixing Mode: Surround Compatible
Other option is "Normal Stereo". I suspect that a third option of "None" would be what I'd want, but alas, it's not there.
DTS Neo:6: Off
I've been through all the FAQs in the sticky threads on this forum, but I'm at a bit of a loss. Any suggestions?
Rich
richunger is offline
post #2 of 4 Old 09-22-2011, 09:21 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi richunger, why not use multi ch analog connection?
JChin is offline
post #3 of 4 Old 09-23-2011, 09:03 PM
Wayne A. Pflughaupt's Avatar
Quoted: 89 Post(s)
Liked: 67
The DVD player should be set for bitstream. However, there may be a menu setting in the Yamaha to activate the Toslink connection.
I wouldn’t worry about that. All that matters is if you get the 5.1 indicator on the Yamaha to light up when you’re watching a movie. That will mean the player is outputting the correct signal, and the receiver is decoding it.
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
post #4 of 4 Old 09-24-2011, 11:28 AM - Thread Starter
richunger's Avatar
I figured out how to get it working with the analog cabling (though I have to manually select "multi channel input" every time I change the input to DVD, which is not so user friendly). I still can't get the yamaha to show a 5.1 input from the samsung when using the toslink connection. I'm starting to think that I'll just have to live with that.
Seems strange that it's just not possible to get a digital 5.1 signal from the blu-ray player to the receiver. I wish I'd realized when I bought the receiver that the HDMI was only pass-through. That's a subtle distinction that I'm sure goes right over the head of most consumers (like me). Oh well, at least it's working.
Samsung Bd C6500 1080p Blu Ray Disc Player , Yamaha Rx V363 Receiver
