LN52A750 as center speaker with Pioneer VSX-D711??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-10-2011, 07:38 PM - Thread Starter
jbbarrette's Avatar
Hello all,
Quick question, I have a Pioneer VSX-D711 (I know, I need a new one) receiver for my surround sound but I'm trying to use my LN52A750 Samsung as the center speaker. My receiver has a center pre-out jack and says to connect to the TV's audio input jack. My question is, which input jack on the back of the TV do I use, if its possible?
Thanks for any help.
jbbarrette is offline
post #2 of 5 Old 10-10-2011, 07:45 PM
holt7153's Avatar
Quoted: 139 Post(s)
Liked: 221
Even if it's possible I'm not sure it's advisable. What are you using for your other speakers?
Anything good in life is either illegal, immoral, or fattening.
holt7153 is offline
post #3 of 5 Old 10-10-2011, 07:47 PM - Thread Starter
jbbarrette's Avatar
The receiver came with small speakers which I have set up around the room. I have no where to put the center speaker with the system and keep it 'center'. So I thought I'd get around it by using the TV as its dead center.....if not, I'll just install the center speaker off to one side a bit a guess.
post #4 of 5 Old 10-10-2011, 07:58 PM
holt7153's Avatar
Quoted: 139 Post(s)
Liked: 221
I wasn't aware the Pioneer VSX-D711 was a HTIB which included speakers? Either way I would try to find a way to use the matching center as opposed to using the TV speaker as a center channel. Why does the center have to be off-center?
holt7153 is offline
post #5 of 5 Old 10-10-2011, 08:01 PM - Thread Starter
jbbarrette's Avatar
No where to mount a center speaker, wife gave me the big NO to mount the speaker on the wall...ha ha. Other surround sound speakers are hidden. Originally bought the system at Costco, maybe they had a deal that included the speakers that no one else had?!?!?
Thanks for the help!
Samsung Ln52a750 52 Inch 1080p Dlna Lcd Hdtv
