Auxiliary speaker for new TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-12-2011, 12:46 PM - Thread Starter
safetyandsecurit's Avatar
I want to attach a simple auxiliary or external speaker to my new flat screen TV. It has red and white audio outputs, but I can't find any speakers that I can wire to it. I know I can use a sound bar, but I'm looking for a cheaper solution. Can you hard-wire today's speakers to the new TVs and get audio output? How?
safetyandsecurit is offline
post #2 of 3 Old 10-12-2011, 12:57 PM
rick240's Avatar
Quoted: 28 Post(s)
Liked: 53
Generally speaking, those connections out from the TV do not respond to the volume control - so you will need to attach to something with volume control.
You probably want either a sound bar or a pair of active speakers (generally associated with computer speakers) and hopefully with a volume remote. Try a search in the forum, there have been threads in the past.
rick240 is offline
post #3 of 3 Old 10-12-2011, 01:06 PM
toofarzong's Avatar
These speakers will fit the bill if you decide not to go the soundbar route. A friend of mine has these and he is quite happy with them.
http://www.audioadvisor.com/prodinfo.asp?number=AUENA2
If you want to go with something a little bit larger.
http://www.audioadvisor.com/prodinfo.asp?number=AUENA5
toofarzong is offline
