Front Speaker pulled forward - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-03-2012, 03:12 PM - Thread Starter
Ericthemidget's Avatar
My setup consists of a Def Tech 8040 center speaker and Mythos on-wall speakers. Because of the size of my tv stand, I need to pull the front speaker forward in order to avoid the sound bouncing off the stand prior to reaching the MLP.
From the MLP, the on wall speakers are 10' and the Center is 8'6". I have this all programmed into my Denon AVR. Are there any issues I need to be aware of?
Ericthemidget is offline
post #2 of 2 Old 01-03-2012, 04:03 PM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
After you get the speakers set up where they work best, you need to set the delay (in milliseconds) for each speaker, assuming your receiver has those settings.
An example: your left and right front speakers measure eight feet from the listening area, and your center speaker measures 10 feet to the listening area. You would delay the center by one millisecond per foot, a total of two milliseconds. That will assure you that all speakers sound reach the listening position at the same time.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
