want to start room measuring and adjustments - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-11-2012, 09:29 AM - Thread Starter
alittletank's Avatar
Liked: 26
Six months ago I had never owned anything audio related more than a boom box. Now I own a Denon 1910AVR with a 5.1 system that includes a BIG diy subwoofer. I realize now that I need to get into measuring and equalization to tune my system in my theater.
3 questions come to mind immediately.
1) What measuring equipment do I need?
2) What inexpensive equalizer would meet my needs?
3) is REW the correct software to use for this purpose?
Of course I am probably not the first to ask these questions so a link to other threads addressing these issues would be great.
I don't know if my room specs and equipment will help at this point but I will post them just in case.
Avr- denon 1910
Subwoofer- DIY lilmike's F-20 with Bash 300 amp
LR fronts. Behringer Truth 2030p
Center- OLD paradigm center ( i know, i know, it should match...)
LR rears-wharfedale wh2
alittletank is offline
post #2 of 5 Old 01-11-2012, 10:05 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Avr- denon 1910
You can use your Denon's Audyssey capability first. If you are not satisfied, get receiver with Audyssey XT32 like 3312.
ap1 is offline
post #3 of 5 Old 01-11-2012, 12:25 PM
Gertjan's Avatar
To measure, you need an SPL meter or proper microphone to do the readings, and then something to write down the readings. You can write things down manually on paper, or in a spreadsheet on a computer, or use software like REW to do this for you much better and faster
You should go read up about REW. Here are some links to get you started:
http://www.hometheatershack.com/foru...on-basics.html
http://www.hometheatershack.com/roomeq/
http://www.hometheatershack.com/forums/rew-forum/
"He who asks feels dumb for a few minutes, but he who does not ask remains dumb forever."
Gertjan is offline
post #4 of 5 Old 01-11-2012, 12:30 PM
nube's Avatar
Quoted: 76 Post(s)
Liked: 442
1) Here's a list of the equipment I purchased to get REW up and running:
http://www.avsforum.com/avs-vb/showt...9#post20592129
Hope that helps, and good luck!
2) MiniDSP is a good solution for EQ'ing. I'm not sure which version you'd need to do your entire system, or if it's even useful to use one in that way. But, it is a great and inexpensive solution for EQ'ing your sub(s).
3) REW is the correct software, yep!
nube is offline
post #5 of 5 Old 01-11-2012, 03:25 PM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 699
Here is a easy 101 read from the gang at gearslutz, Basic acoustic measurement primer v2.1
Ethan's site is a good read also
http://www.ethanwiner.com/acoustics.html
and this one at realtraps
http://www.realtraps.com/art_measuring.htm
mtbdudex is offline
