Front wall damping or baffle wall - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-20-2012, 06:29 AM - Thread Starter
atledreier's Avatar
Quoted: 22 Post(s)
Ok, I'm going to take my screen down and do some changes to my setup, and thought I might do some more acoustic work back there while i was at it. So, I've been considering a baffle wall. Seems like a great idea for the front stage, but it won't do much for the rest of the room, so to speak.
The other option is to more or less fill any area that is not taken by speakers with some light insulation (approx. 5000rayls/m) from the actual wall and all the way to flush with the front baffles of the speakers. That is about 80cm or 2'6". I know we're talking about ALOT of damping here, but that's ok with me. Calculations tel me this huge basstrap will be pretty effective even down low. I have classic chunk-style traps in all wall-wall corners made of OC703-equivalent material (Rockwool, 25000rayls/m)
The bafflewall will do very little for me down low, and will potentially give me a little less SBIR. I get 6dB headroom that I don't need and potential construction issues with the actual baffle. I'm leaning toward the insulation experiment, myself. Easier, cheaper and potentially more benefit. I would assume packing the speakers with insulation will help SBIR maybe even more effectively than a baffle wall?
I'm thinking something along the lines of this:
"Unplugging the signal cable is pretty much the ultimate in component isolation. Now if you removed the AC power and it still did it you should look for the little blond girl saying "they're he-re."
atledreier is offline
post #2 of 6 Old 08-10-2012, 01:33 AM
JonasHansen's Avatar
Quoted: 141 Post(s)
Liked: 48
I'm in the same situation as you - what did you end up doing?
Home Theater: JBL M2 & SUB18 powered by Crown and BSS.
JonasHansen is offline
post #3 of 6 Old 05-20-2014, 01:44 AM
Lindahl's Avatar
Quoted: 24 Post(s)
Curious about this as well. Any updates/conclusions?
I posed the question, here, as well:
http://www.acousticfrontiers.com/home-theater-blog/2013/3/22/baffle-walls
Lindahl is offline
post #4 of 6 Old 05-22-2014, 09:05 PM
uopdrmark's Avatar
Quoted: 72 Post(s)
uopdrmark is online now
post #5 of 6 Old 05-23-2014, 12:19 PM
tvrgeek's Avatar
Quoted: 18 Post(s)
Liked: 33
Those big 2 x 4's may be a bit of an issue. The expert on this is Floyd Toole. He literately wrote the book. I found 2 inches of OC 704 to be just fine. Plain old insulation is not as effective.
tvrgeek is offline
post #6 of 6 Old 05-23-2014, 02:18 PM
Lindahl's Avatar
Quoted: 24 Post(s)
Plain insulation is more effective at 8" or more. Check out the measurements and calculations over at gearslutz.com
Lindahl is offline
