Question about DACs - Page 19 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #541 of 546 Old 02-12-2012, 08:42 AM
Super Moderator
markrubin's Avatar
Quoted: 1244 Post(s)
Liked: 2754
Originally Posted by markrubin View Post
this thread may have outlived its usefulness....
Originally Posted by arnyk View Post
If you locked it from future updates, I for one wouldn't feel hurt. OTOH, the same interchange will probably show up in another thread within days or hours...
while the thread remains open, kindly limit further posts to technical issues
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess this is a red flag issue
HDCP = Hollywood's Draconian Copy Protection system
Test Reports HDMI Cables that support 18GBPS&HDMI 2.0b
markrubin is offline
post #542 of 546 Old 02-12-2012, 08:57 AM
audiophilesavant's Avatar
I have read the paper.
I do not find it surprising that different opamps sound different.
The question is which opamps were tested. Were they old, were they new, were they cheap, were they expensive? Which ones measured best? Which ones measured worst? Which ones were preferred? What was the correlation, if any, between age, cost, measurements and other factors, and preference?
I do think it is interesting that the study concluded that opamps which had more distortion were preferred. What was the nature of the distortion in those opamps which were preferred?
The paper would appear to suggest that chasing the best possible numbers does not always result in the "best" possible sound, where "best" is determined by preference.
Perhaps all of those Harman DBTs have resulted in amplifiers and speakers being unleashed on the market which were not those that had the best measurements, but which nevertheless were preferred by trained listeners.
Some may be interested in owning equipment which has the best possible measurements regardless of how it sounds. Others may be interested in owning equipment which sounds best to them, regardless of measurements. Think tube vs. solid state, analog vs. digital, USB vs. S/PDIF, negative feedback vs. no negative feedback.
Do you want to own a DAC or use a digital interface which has lower jitter but sounds worse than a DAC or digital interface with higher jitter?
Should you offer equipment for sale to your customers which has better measurements or which sounds better? Should they be offered a choice?
Which equipment has better performance - equipment which measures better or equipment which sounds better?
audiophilesavant is offline
post #543 of 546 Old 02-12-2012, 09:21 AM
David James's Avatar
Quoted: 40 Post(s)
Liked: 80
I think you bring up a very interesting discussion point with your last sentence perhaps the best way of summing up the subjectivist vs. objectivist debate.
For me, the ultimate goal has always been to reproduce the sound as intended from the artist/producer/etc. That means adding / subtracting nothing. So the key is, how can I know that's what I'm getting. The answer I always come up with is, how the heck will I ever know what was in the mind of those that made the recording? I don't think I ever will so I settle on what seems logical, try to stick with equipment which passes through the source without modification, which leads me to look at measurements and where they deviate, the audibility of those deviations.
David James is offline
post #544 of 546 Old 02-12-2012, 11:58 AM
Bigus's Avatar
Quoted: 397 Post(s)
Liked: 385
[quote="stereoeditor"]
"The decision to use the distortion selective amplifier configurations rather than a more conventional circuit implementation was made in order to maximize the listener's ability to hear a shift in character for the op- amps. The test configuration increases the level of the op-amps' inherent characteristic distortion, allowing listeners greater differences to assist with the discrimination tests.
[quote]
Did we really need a listening test to show us that if you isolate and amplify the distortion of various opamps which are measurable different we can eventually hear those differences? Would it not be enough yo just say they measure differently and use logic to show the above? And conversely, if we are curious whether opamps can cause audible distortions under normal (reasonably well designed) implementations, what usefulness is the above test?
Although somewhat exaggerated, these are the same types of differences that might be heard with more conventional circuit implementations.
It appears the authors have now made a leap not at all supported by the test they devised. I see this often in all sorts of journal articles so it isn't uncommon.
I'll hold further comments until I've had a chance to read the paper. Perhaps I'm missing something critical not captured in these quote snippets.
Bigus is offline
post #545 of 546 Old 02-12-2012, 12:33 PM
natchie's Avatar
Quoted: 28 Post(s)
Liked: 32
Thanks Arny. I was wondering about the high price of this DAC product. I am using a Xonar USB piece also by ASUS...but it seems to be pretty awkward and accident-prone...already popped the cover off..
A number of people have tested this product. If you search on "Asus Xonar Essence One Rightmark" (without the quotes), you will find a bunch of them.
There are a ton of good-sounding USB DAcs starting at well under $100. This looks like an audiophile product - for people who are obsessive about having the best even though you can easily get as good sound for maybe 1/10th the price.
natchie is offline
post #546 of 546 Old 02-12-2012, 01:40 PM - Thread Starter
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
Ya think?
domino92024 is offline
Closed Thread Audio Theory, Setup, and Chat
