Wood Blocks Under Speakers - AVS Forum | Home Theater Discussions And Reviews
Old 02-02-2012, 08:13 AM - Thread Starter
greylight44's Avatar
Quoted: 24 Post(s)
Liked: 24
What's the consensus on using wood blocks under speakers to improve sound? My Mirage M5si speakers are on a carpeted concrete floor and I've read that can degrade the sound. Wood blocks/cutting boards made of maple are expensive but bamboo is quite a bit cheaper. I've read pros and cons elsewhere and would like to hear AVS Forum members views on this topic.
greylight44 is offline
Old 02-02-2012, 08:20 AM
sivadselim's Avatar
Quoted: 159 Post(s)
Liked: 154
Not sure what your goal or logic might be, exactly, but marble or granite tiles can work well, too, if you are just trying to get a hard surface beneath the speakers.
Also, consider spikes.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is online now
Old 02-02-2012, 08:51 AM
underminded999's Avatar
Quoted: 29 Post(s)
As long as the wooden blocks are covered with carpet, they should work fine-ish.
The idea is to de-couple the speaker from the hard floor surface.
To do this, you would:
A) Rise the speaker off of the floor, giving the sound more room before deflecting off of the floor.
2) Use a dampener such as carpeted wood, or any manufactured dampening material.
III) Mount the speaker on legs, such as small table legs available at any home improvement store.
The reason to de-couple is to stop the speaker cabinet from interacting with the hard floor.
I know that I have seen threads where people have made there own, using 1x1's, plywood, and carpet remnants.
Alternatively, some people just use small carpets under their speakers.
I currently, have been unable to locate any of these threads, but I know I have seen them somewhere, either here or over at Bluray.com.
Maybe someone else can link to them and/or provide pix.
To the OP, are you experiencing sound issues? What prompted your inquiry?
underminded999 is offline
Old 02-02-2012, 09:03 AM - Thread Starter
Quoted: 24 Post(s)
Liked: 24
I enquired because I've read that a carpeted concrete floor versus, I guess, a suspended wood floor is the worst place to put a speaker. I have the M5's spiked down to the concrete but was wondering if the over-all sound could be improved by using a 2" thick rectangular block of wood under the speakers. Does anyone have experience with this tweak?
Old 02-02-2012, 09:07 AM
sivadselim's Avatar
Quoted: 159 Post(s)
Liked: 154
No, actually the usual idea is to couple the speakers to a hard surface.
Really?
BTW:
Originally Posted by greylight44 View Post
My Mirage M5si speakers are on a carpeted concrete floor..........
Old 02-02-2012, 09:08 AM
Quoted: 29 Post(s)
I don't think that it'll matter much.
Now, if you only had the speakers sitting on bare concrete, then you would hear a BIG difference by de-coupling the speaker from the floor.
But since, you say the floor is already carpeted, then you probably would not see much improvement by adding a riser of some sort.
Old 02-02-2012, 09:15 AM - Thread Starter
Quoted: 24 Post(s)
Liked: 24
Thanks for getting the discussion going. Maybe Mapleshade just wants to sell some expensive chunks of maplehttp://shop.***************.com/18-x...fo/18X15X2-CL/
Quoted: 29 Post(s)
That is not how I understood it, but hey, who knows.
It has always been my understanding that some speakers interact poorly with hard surfaces. To to overcome this, you would want to de-couple it, by raising the speaker in space, giving the sound more room before it starts to interact with the hard surface areas.
I gathered most of this idea from some subwoofer forums.
But I may be off base, so if someone else is in the know, then I defer...
For the record, I have never raised my speakers, and can neither attest to or deny the reality of said application(s).
Old 02-02-2012, 10:26 AM
Easyaspie's Avatar
Since, more often than not, we aren't really able to trully 100% couple a speaker to the floor, decoupling is neccessary.
Take spikes for instance. Some say they decouple, I say used properly they couple the speaker to the floor. The weight of the speaker is transferred to the floor through 4 tiny points as opposed to the entire bottom of the speaker. That, IMHO, couples it.
Since the OP has concrete iunderneath his carpet, he cannot couple the speaker to the floor. I don't think anything he does is going to make much of a difference.
One thing that may have an effect would be a couple of those subdudes or something similar. They may offer isolation as well as still providing a study base.
Easyaspie is offline
Old 02-02-2012, 11:21 AM
localhost127's Avatar
Quoted: 25 Post(s)
Liked: 58
sorbothane.
localhost127 is offline
Old 02-02-2012, 11:28 AM
AJinFLA's Avatar
Liked: 24
If the speakers are parked in your driveway or front lawn, your HOA/Code enforcement might have something to say about it.
cheers,
AJ
AJinFLA is offline
Quoted: 29 Post(s)
"Sorbothane® is a highly damped, visco-elastic polymeric solid that flows like a liquid under load."
Now that sounds scary, it's like Spiderman's Symbiote, trying to take over...
Old 02-02-2012, 03:56 PM
dknightd's Avatar
Probably does not matter
Everything I say here is my opinion. It is not my employers opinion, it is not my wife's opinion, it is not my neighbors opinion, it is My Opinion.
dknightd is offline
Old 02-02-2012, 03:57 PM
dknightd's Avatar
Yep. They are a business and have to make money to survive.
dknightd is offline
Old 02-02-2012, 04:09 PM
sivadselim's Avatar
Quoted: 159 Post(s)
Liked: 154
Originally Posted by localhost127 View Post
sorbothane.
Yeah, on carpet, if it were me, I would just put marble or granite tiles (or wood) underneath the speaker with some sort of bumpers on each of the corners of the speaker's base. You can stick the bumpers to the tiles/blocks if you want to avoid sticking them to the speakers.
Old 02-02-2012, 04:19 PM
DonH50's Avatar
Quoted: 1790 Post(s)
Liked: 1323
You might want to read this interesting article: http://www.whatsbestforum.com/showth...o-loudspeakers The author "is" Genesis and knows a thing or two about speakers...
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
Old 02-02-2012, 05:34 PM
dknightd's Avatar
I didn't read the whole thing, but did not see any mention of wood blocks.
dknightd is offline
Old 02-02-2012, 06:08 PM
dknightd's Avatar
To the OP, If you want to experiment with wood blocks I encourage you to. I'm frugal, so I'd start with 2x4 or 4x4 available at lumber store. If I noticed a difference, I might experiment with other woods - No doubt each wood has different characteristics. And each concrete floor is unique. It is an area worth experimenting in. Especially since you are interested and curious.
dknightd is offline
Old 02-02-2012, 07:08 PM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 816
If you put wooden blocks under the speakers, do you also have to wear Dutch wooden clogs?
"I've found that when you want to know the truth about someone that someone is probably the last person you should ask." - Gregory House
Chu Gai is offline
Old 02-02-2012, 08:18 PM
Gertjan's Avatar
I stopped reading at
For whatever reason, we find copper pennies to sound far better than zinc pennies
"He who asks feels dumb for a few minutes, but he who does not ask remains dumb forever."
Gertjan is offline
Old 02-02-2012, 10:12 PM
filecat13's Avatar
Quoted: 34 Post(s)
Liked: 101
That's optional, but a Dutch wooden codpiece is recommended. I can source one if you'd like.
What I can afford, when I can afford it...
filecat13 is offline
Old 02-03-2012, 12:23 AM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
Depends on the speaker, really. Up until a few years ago, I had a pair of Pioneer HPM-100 speakers hanging from the ceiling. The bottom of each speaker was about 3-feet off of the ground. Got rid of a touch of "boomy" bass.
domino92024 is offline
Old 02-03-2012, 01:25 AM
LINEARX's Avatar
Placement of the speakers in your room will mean more to the response curve and the spatial attainment than any relationship the speaker cab has with the floor. Contacting or NOT contacting the floor is unimportant in perceived sound quality.
Equidistant placement from walls AND ceiling will yield optimum soundstage. However furniture placement and room shape generally impede on best auditory practices.
You seldom see subs hanging midway between floor and ceiling . . . . because they're big . . . and because they're heavy . . . . NOT because they don't sound great.
LINEARX is offline
Old 02-03-2012, 06:51 AM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 816
My fading memory says Genisis "was" Arnie Nudell. As to what the author who now "is" Genisis, my take is that it's like listening to a Scientology pitch or Kevin Trudeau on an infomercial.
Talk about knock on wood, huh?
Chu Gai is offline
Old 02-03-2012, 11:03 AM
Speed Daemon's Avatar
Quoted: 91 Post(s)
Liked: 47
This reminds me of the vendor at a CES that was selling twist-ties and assorted bits of junk that he claimed would improve the sound. Many people swore they heard a marked improvement, and sales of $50 ea. twist ties were brisk.
True story.
You get what you pay for.  For professional advice, pay the professional rate.
Speed Daemon is offline
Old 02-03-2012, 11:10 AM - Thread Starter
Quoted: 24 Post(s)
Liked: 24
You're hilarious.
Old 02-03-2012, 11:33 AM
Quoted: 25 Post(s)
Liked: 58
equidistant placement yields maximum SBIR. are you insisting that is a good thing?
so you're interested in a null re: the vertical axial mode?
Old 02-03-2012, 11:37 AM
Quoted: 25 Post(s)
Liked: 58
Old 02-03-2012, 01:05 PM
Gertjan's Avatar
I would like to point to the "S" in AVS
Gertjan is offline
Old 02-03-2012, 02:41 PM - Thread Starter
Quoted: 24 Post(s)
Liked: 24
I've purchased some cheap but solid bamboo cutting boards that the M5's will fit on nicely. I will try them out this weekend.
