Audioengine A5+ and AS8 - AVS Forum | Home Theater Discussions And Reviews
Old 02-02-2012, 04:24 PM - Thread Starter
jav1's Avatar
Quoted: 23 Post(s)
Hi,
I'm trying to achieve a setup where the sub handles virtually all lower-end frequencies and the A5+ just focuses on the upper mids and highs. My setup is a PC optical out into a DAC. DAC analog out into the A5+ inputs. A5+ varibale audio out to the AS8 inputs.
The problem is despite setting crossover at 130 the A5+ are still outputting low-end frequencies and I'm getting a "double bass" effect. I verified that the A5+ was still playing low-end frequencies by setting the xover at 130 and turning the volume completely down on the sub, instead of hearing thinner sound from the A5+, I heard the full range. Checking the xover section on page 6 of the AS8 manual it should not behave like this. Any idea why the A5+ continues to play the full range. Do I need a receiver to manage bass? I thought the sub would handle it.
I also tried an alternate connection method with the same result (A5+ continues to play full range). For this connection I tried PC Optical out to DAC. DAC analog out to the AS8 inputs and AS8 outputs to A5+ inputs.
jav1 is offline
Old 02-02-2012, 06:31 PM
dknightd's Avatar
Originally Posted by jav1 View Post
Hi,
You might want to contact the people who made the product you bought.
Everything I say here is my opinion. It is not my employers opinion, it is not my wife's opinion, it is not my neighbors opinion, it is My Opinion.
dknightd is offline
Old 02-02-2012, 07:59 PM - Thread Starter
jav1's Avatar
Quoted: 23 Post(s)
Yep, have an email into them... I'm hoping to hear from anyone who may have an identical setup..
jav1 is offline
Old 11-11-2012, 02:20 AM
Scott Nicolson's Avatar
The A5+'s internal crossover doesn't have a low frequency cut off and will play full range if given any chance, but im sharing your pain bro, it would be great if they did. The best i can figure is to have one line running to the A5+, set your crossover for them AND then run a separate line for the sub.
Scott Nicolson is offline
Old 11-11-2012, 08:11 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Hi,
You need a electronic crossover like a Behringer DCX 2496.
The problem is that the most economical way to get such a thing seems to be by obtaining a low end AVR.
The practical and economic aspects of that solution aren't so good.
You end up buying a lot of hardware you bought the AE speakers to avoid.
Someone needs to make a box that is the DSP and inputs of an AVR with line outputs and no power amps. Trouble is, doing that for less money than a low end AVR is probably mission impossible.
Welcome to the wonderful world of economies of scale!
arnyk is offline
Old 09-03-2015, 01:20 PM
Liked: 0
Sorry to bring this back up, but have you found a solution to this yet?
Steven San Marzano is offline
Old 09-03-2015, 04:40 PM
henrich3's Avatar
Quoted: 573 Post(s)
Liked: 495
If you have an S8 sub, connect your source's audio out to the audio input on the sub, then connect the audio out on the sub to the audio input on the A5. Adjust the sub's crossover, volume, and the A5's volume to get a proper blend.
Here's a FR chart of my A5+ (red) and the A5+ with the S8 sub (blue):
The Volume control on my S8 is set at the 9:30 o'clock position, and the Crossover knob points to the 1:30 position. The A5+ doesn't have a mark on it's Volume knob, so I can't say how that's set. My speakers & sub are attached to a digital piano, and I use the Volume control on that device to control the volume of the speakers & sub.
henrich3 is offline
