cant get audio from optical 5 on yamaha 2000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-12-2012, 12:16 PM - Thread Starter
digitalhiss's Avatar
Ok, I am stumped? I have a computer that feeds audio to my yamaha 2000 receiver via optical. I have the optical plugged into optical 5 on the receiver (audio 1 (tv 2) area) and is giving me no sound. I had it hooked up before to an older receiver and had no isues! I have checked menu's and settings for 2 hours and I am completely stumped. I am not sure if it is the computer end or receiver but pretty sure it is a setting on the receiver as it worked from the computer in the past. Any sugestions? I have tried other optical inputs on receiver and nothing.
digitalhiss is offline
post #2 of 5 Old 02-12-2012, 01:01 PM - Thread Starter
I have to be overlooking something realy simple???? If i do an audio test in the audio setup screen on the pc it sends, and I can hear, the test tones via the receiver but I still get no music when sent from pc?
post #3 of 5 Old 02-12-2012, 01:17 PM
kmannth's Avatar
Check your computers audio device settings. Make sure it is configurd to use the optical and not the regular analog out or hdmi.
Good Luck!
kmannth is offline
post #4 of 5 Old 02-12-2012, 01:37 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
What is your source material? What software are you using for your music player?
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #5 of 5 Old 02-12-2012, 03:46 PM - Thread Starter
my settings appear to be ok as i can get sound out via the pc's speaker test function. the music files are your standard mp3 files. I run windows 7 , quad core i7 with 8 channel audio capable mb.
