No sound on front speakers! Help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-20-2012, 05:04 PM - Thread Starter
engecc's Avatar
I have a surround sound system. I am getting no sound out of my front speakers. The only sound i get is from my center speakers and sub. When i run the test tone, the front speaker tone plays out of the sub. Any ideas??
engecc is offline
post #2 of 10 Old 02-20-2012, 05:06 PM
gregzoll's Avatar
Liked: 33
Check all connections, and settings.
gregzoll is offline
post #3 of 10 Old 02-20-2012, 05:17 PM
Ken H's Avatar
Sounds like you have the cables connected incorrectly.
Is the sub powered? How does it get its signal?
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #4 of 10 Old 02-20-2012, 05:29 PM - Thread Starter
engecc's Avatar
sub plugs into regular AC outlet. I have sub out going to speakers and input coming from receiver. The is a component plug on receiver for sub, but there is one one reciever and a right and left component plug on sub.
engecc is offline
post #5 of 10 Old 02-20-2012, 05:49 PM
Roger Dressler's Avatar
Quoted: 1861 Post(s)
Liked: 987
Sub out to speakers? You'll need to draw a diagram. This makes no sense.
Current: Deadwood II Theater
Previous: Deadwood Atmos theater [HTOM]
SSP-800 PLIIx 7.4; Anthem AVM 60 7.4.4, MiniDSP OpenDRC-AN
Aerial Acoustics 7B/CC3B fronts, KEF Ci200QS surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
JVC RS520; Stewart Cima Neve 115"W x 49"H 2.35 screen
Roger Dressler is offline
post #6 of 10 Old 02-21-2012, 05:12 AM
gregzoll's Avatar
Liked: 33
They are using the Powered Sub to power the speakers.
gregzoll is offline
post #7 of 10 Old 02-21-2012, 06:43 AM - Thread Starter
engecc's Avatar
ok, so I left all the wiring the same. Hooked up the rear speakers to the front wires and worked like a champ. Clearly the front speakers are the issue. Is there a fuse or other component in the speakers that could have gone bad that i could replace/solder?
P.S. Thanks for all the help guys, yall are a bug help
engecc is offline
post #8 of 10 Old 02-21-2012, 08:53 AM
Liked: 987
Then he could have said it, just as easily as you did.
Care to tell us the model number(s) of the gear? Could be useful in answering questions.
post #9 of 10 Old 02-23-2012, 10:14 AM
DoyleS's Avatar
Quoted: 35 Post(s)
Liked: 25
You are going to have to test your front speakers to see if they are good. If you have a DVM (ohm meter) you can check the resistance. It should be very close to zero. If you have no equipment and need to check the speakers you can take a 1.5 volt battery like a AA cell and quickly touch the speaker wires to the battery positive and negative and you should get a click or pop in the speaker if it is connected. If it does not, then thoroughly check those wires to see if they indeed are connected to the speaker terminals. It may be that the speakers are bad. Did they ever work? Is this the first time you are connecting it? Like others have said, please post the make and model number of your system, it makes it a lot easier for us to understand possible problems.
M&K S150THX LCR, SS150THX Tripoles, 4 Speakercraft Aim-7 for Atmos
B&K AV5000 driving the M&Ks
Denon X4300H AVR
"So many tweeks....So little time!"
DoyleS is offline
post #10 of 10 Old 02-27-2012, 08:42 AM
dharel's Avatar
Liked: 33
Just so we're clear, where are the front speakers connected when they don't work? The sub or the AV receiver? If the sub, try connecting the speakers directly to the AV receiver.
dharel is offline
