SPL Meter Aiming & Reading - AVS Forum | Home Theater Discussions And Reviews
post #1 of 27 Old 02-22-2012, 07:24 PM - Thread Starter
OzzieP's Avatar
A couple of questions on balancing the home theater sound with a Radio Shack SPL meter.
1. Which direction should the microphone point at?
I have read various answers for this and after trying all of them the results are different so I think it is important to establish the proper way of pointing it. I have read that pointing it at each individual speaker from the listening position allows you to get a true reading for each speaker individually. Its a bit hard since you have to repoint your meter for each speaker but if this is the most accurate way then why not.
I have also read that you aim the SPL meter from the listening position directly to the ceiling, that way you get a more balance sound from each speaker and it does not require re-aiming the SPL meter.
I have also read that one should point the SPL meter from the listening position directly to Movie Screen since this is they way you will be listening to your theater therefore it is the way it should be calibrated. Sounds reasonable but is it the correct way, in fact which is the correct way?
2. Various reports show the the Radio Shack SPL meter is not so accurate on the low frequency range and have posted correction values such as this;
10hz........+20db
12.5hz.....+16.5db
16hz........+11.5db
20hz........+7.5db
25hz........+5db
31.5hz.....+3db
40hz........+2.5db
50hz........+1.5db
63hz........+1.5db
80hz........+1.5db
100hz......+2db
125hz......+.5db
160hz......-.5db
200hz......-.5db
250hz......+.5db
315hz......-.5db
400hz......0db
500hz......-.5db
630hz......0db
800hz......0db
1k...........0db
1.25k......0db
1.6k........-.5db
2k...........-1.5db
2.5k........-1.5db
3.15k......-1.5db
4k...........-2db
5k...........-2db
6.3k........-2db
8k...........-2db
10k.........-1db
12.5k......+.5db
16k.........0db
20k.........+1db
So if I measure my LFE at 20Hz and it reads 80 DB's on the SPL meter does that mean it is actually 87.5 DB's in which case if 80 DB is the target I need to lower the volume by 7.5 DB's down to 72.5?
3. What crossover frequency should be used?
I read that most settings recommend setting your crossover to 80 hz, I think that is also the THX standard as well. However when reading manuals and set up guides for sub woofers they seem to think that 60 hz (assuming your mains do well there)is ideal for good bass.
OzzieP is offline
post #2 of 27 Old 02-22-2012, 07:45 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Definitely don't do it this way.
Not this way either.
Don't do it this way, either.
Aim the meter at the point between your front speakers and above your center speaker where the wall behind your front speakers meets the ceiling.
Provided that correction table's values are correct, yes. But why do you have a "target" for 20Hz?
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #3 of 27 Old 02-22-2012, 07:52 PM
Speedskater's Avatar
Quoted: 20 Post(s)
An SPL meter is best used to set the individual channel levels. I would mount it on a tripod or mic stand at the main listener's seat and aim it straight up.
For frequency response checks I would use a calibration mic.
The Radio Shack SPL meter correction charts are about worthless. These mics have been manufactured for decades, probably in different factories with many different suppliers for all the internal parts. From batch to batch the frequency response is all over the map.
I'll let others answer your other questions.
Kevin
Speedskater is offline
post #4 of 27 Old 02-22-2012, 09:53 PM - Thread Starter
OzzieP's Avatar
sivadselim
Thanks for the Reply, You suggest;
This would be my center speaker.
O.K. then above my center speaker aiming to the point where the ceiling meets the wall. I have a pretty high ceiling and if I put this angle from the listening position it will point approximately 60 degrees up.
Is there a logical or acoustic reason for aiming it this way?
OzzieP is offline
post #5 of 27 Old 02-22-2012, 09:58 PM - Thread Starter
OzzieP's Avatar
Speedskater
I understand the Radio Shack is probably the poor mans version of a calibration microphone which last time I checked they the cheap one of those cost about 15 times the price of the radio shack version plus you still need a device to display the results of this microphone. I do have to agree with you that those SPL correction charts are probably useless for the reason you stated, but I suspect it does reflect where the flaws are in the Radio Shack SPL (Low Frequencies).
Do you have a calibration microphone you recommend?
OzzieP is offline
post #6 of 27 Old 02-23-2012, 12:11 AM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
........it will point approximately 60 degrees up.
OK
Because it looks cool as fonk.
post #7 of 27 Old 02-23-2012, 01:53 AM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
I bought mine, Behringer ECM8000, from Herb Singleton, founder of Cross-Spectrum
http://www.cross-spectrum.com/
Very reasonable prices for a calibrated mic.
I use that for all acoustic measurements, and the RS SPL meter for pink noise dbl level setting only.
mtbdudex is offline
post #8 of 27 Old 02-23-2012, 05:15 AM
localhost127's Avatar
Quoted: 25 Post(s)
Liked: 58
http://www.gearslutz.com/board/studi...c-ceiling.html
localhost127 is offline
post #9 of 27 Old 02-23-2012, 05:58 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Speedskater
I second the recommendation of the Behringer ECM8000. I've probably bought a dozen over the years (people keep borrowing them and not returning them!). Cheap, effective and reasonably reliable. For under $60 if it gets lost, damaged or dies, so what?
You also need something like a USB computer audio interface with XLR mic inputs and phantom power. There are many good competitive devices, with the M-Audio Mobile Pre probably being one of the more highly regarded and popular.
Finally, you need some good measurement software. Room Equalization Wizard is good, well supported freeware. I believe that there is a conference related to its use here on AVS.
arnyk is offline
post #10 of 27 Old 02-23-2012, 06:28 AM
gregzoll's Avatar
Liked: 33
Another recommendation for REW. Just use a good quality microphone with the program.
gregzoll is offline
post #11 of 27 Old 02-23-2012, 09:17 AM - Thread Starter
OzzieP's Avatar
Found the ECM8000 for $54, and the REW software, still trying to find what to interface the microphone to the laptop with.
I think this would work:
http://www.m-audio.com/products/en_us/FastTrack.html
$149
OzzieP is offline
post #12 of 27 Old 02-23-2012, 11:32 AM
Quoted: 25 Post(s)
Liked: 58
$149
ART USB DUAL-PRE
http://www.bhphotovideo.com/c/produc..._Dual_Pre.html
$69
post #13 of 27 Old 02-23-2012, 11:46 AM
Ethan Winer's Avatar
Quoted: 264 Post(s)
Liked: 359
Exactly. This may help too:
Comparison of Ten Measuring Microphones
--Ethan
Ethan Winer is offline
post #14 of 27 Old 02-23-2012, 12:42 PM - Thread Starter
OzzieP's Avatar
Originally Posted by localhost127 View Post
ART USB DUAL-PRE
$69
That Dual Pre look like will do the trick and good price, but it has more
knobs than I expected. I have no clue what phantom on or off is for, and would one need to use the gain if your just taking spl readings? I am hoping it comes with instructions. I have taking readings with a radio shack SPL and a test CD with various frequencies but have never really use gain or phantom.
OzzieP is offline
post #15 of 27 Old 02-23-2012, 01:16 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
That Dual Pre look like will do the trick and good price, but it has more knobs than I expected.
Set to "on" to make sure the mic gets the power that it needs to operate. It's good switch to turn on and just leave on, because if the mic doesn't need the power, it won't take it.
Use the gain control to obtain the desired vertical position of the graph in whatever analysis software that you are using.
Your best source of instructions will come with the software, and advice you can obtain from this forum.
Here is a relevant thread in *this* forum:
"Room EQ Wizard (free measurement and parametric EQ setup software)"
I have taking readings with a radio shack SPL and a test CD with various frequencies but have never really use gain or phantom.[/quote]
arnyk is offline
post #16 of 27 Old 02-23-2012, 02:32 PM - Thread Starter
OzzieP's Avatar
Thanks, now wait for it to arrive and hook it all up, hopefully mac compatible or else I will have to use my old windows laptop.
So the consensus is to aim the mic toward the ceiling and floor area above the center channel then.
OzzieP is offline
post #17 of 27 Old 02-23-2012, 04:48 PM
dknightd's Avatar
REW will run on a Mac. I think for most home measurements where you put the mic matters more than which way you aim it. Of course I'm prepared to be wrong.
What are you trying to measure?
If you are just looking at room modes, or trying to integrate a sub with mains, you can likely get useful results using REW and your radioshack SPL meter (nothing to buy assuming you have cables to connect your mac to your receiver, and to the RS meter.) Sure they may not be the most accurate, but they can still be useful. And it will let you get used to the software while you wait for your other new toys to arrive
Everything I say here is my opinion. It is not my employers opinion, it is not my wife's opinion, it is not my neighbors opinion, it is My Opinion.
dknightd is offline
post #18 of 27 Old 02-23-2012, 06:05 PM
Glimmie's Avatar
Quoted: 725 Post(s)
Liked: 591
When Dolby sweeps a theater they use four microphones in each corner of the seating area all aimed up at the ceiling.
I have tried both aiming at the screen and aiming at the ceiling at home and prefer the aim to ceiling results.
Glimmie is offline
post #19 of 27 Old 02-23-2012, 06:22 PM
Quoted: 25 Post(s)
Liked: 58
you "prefer", as in they give you a better "looking" (more "pleasing") response on the graph, or a more accurate response of the actual acoustical behavior of the space.
you should consult with the mic mfg'r on their recommended orientation. eg, is it free-field (direct) mic, or diffuse-field ?
post #20 of 27 Old 02-23-2012, 07:00 PM
dknightd's Avatar
Can you explain to me the difference between the two? And how they should be best used? This is not a test, I'm just looking to learn without wasting hours on google. The terminology seems to be all over the place. I'm sure this terminology means something to somebody familiar with microphones, but not much to me. If you you know the difference, great - please share. If not, no problem, I'll look it up later if I think it matters. Thanks.
dknightd is offline
post #21 of 27 Old 02-23-2012, 07:51 PM
Quoted: 25 Post(s)
Liked: 58
free-field is relevant for non-environment or anechoic rooms - eg, direct signal is what is being measured. diffuse-field for a non-anechoic room with reflections.
http://www.globalspec.com/learnmore/...nt_microphones
"Free field microphones are used to measure a plane wave that is propagating freely in one defined direction. Diffuse field measurement microphones, also known as random incidence microphones, measure sound waves from all directions."
http://www.acousticvibration.com/mea...icrophones.htm
check with the manufacture of the mic as for recommended orientations re: diffuse-field mics (eg, 70* on-axis). free-field should be pointed at the source.
this is an inexpensive and popular mic for room measurements:
http://www.daytonaudio.com/index.php...icrophone.html
post #22 of 27 Old 02-23-2012, 08:26 PM - Thread Starter
OzzieP's Avatar
That would explain all of the different ways that these measurements are being taken. I know the Audyssey Microphone point straight up when they take their measurement. I would not be surprised then that tons of people that have been trying to balance there sound have microphones pointed in all sorts of direction and getting incorrect results.
That Dayton microphone also looks like a nice one, I assume that is a Diffused Field Microphone, so in that case if your trying to balance your sounds which direction should it be oriented?
OzzieP is offline
post #23 of 27 Old 02-23-2012, 08:37 PM
Glimmie's Avatar
Quoted: 725 Post(s)
Liked: 591
I prefer the sound results of the ceiling aim.
Glimmie is offline
post #24 of 27 Old 02-24-2012, 01:55 PM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
btw, I have a 2009 27" i7 iMac and REW on the Mac OsX platform works - no need to run VMWare, just like WinDoz there are some quirks here and there, support on HTS page may have tips for you.
mtbdudex is offline
post #25 of 27 Old 02-24-2012, 02:42 PM
fotto's Avatar
Quoted: 21 Post(s)
Here's a good read regarding mic's...Herb from Cross Spectrum sells these with cal files (various ordering options). He suggests 10-20 degrees off vertical (where vertical is capsule pointed at ceiling). I bought the Dayton EMM-6 with "Basic Plus".
http://www.hometheatershack.com/foru...rvice-usa.html
http://www.cross-spectrum.com/measur...ed_dayton.html
fotto is offline
post #26 of 27 Old 02-24-2012, 02:47 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
FWIW< here's Ethan Winer's short take from his measurement mic test linked above
"Although omnidirectional microphones supposedly receive sound equally from all directions, when measuring rooms and loudspeakers the convention is to "aim" the microphone upward. No omni microphone has exactly the same frequency response from all directions, though microphones with tiny diaphragms and slim bodies are often more uniform than larger models. So when balancing loudspeaker volume levels on a surround system, pointing the microphone toward the ceiling favors all of the loudspeakers equally."
I'd add that if you want to capture the room effects that Audyssey is attempting to correct for, straight up seems to make the best sense overall - - equally favoring at least 360 degrees on the vertical plane of the mic.
JHAz is offline
post #27 of 27 Old 02-24-2012, 05:01 PM
Quoted: 20 Post(s)
Speedskater
The Radio Shack meter is a surprisingly good SPL meter (at least mine is) but not so good as a cal. mic.
I have two older ECM8000 mics and an even older Mity-Mic. But other good options are available now.
Kevin
