How to aim in-ceiling speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-23-2012, 10:24 AM - Thread Starter
logicology's Avatar
I have Sonance 623R in-ceiling speakers. I use these as surrounds in a 5.1 system with Ascend RAAL Towers and a Sierra-1 NrT Center. (...I know in-ceiling speakers are not ideal, but it's what I have to work with.)
I can aim the woofer and tweeter individually. I'm wondering if it's recommended to aim the speakers directly at the listening position, or aim it at the back wall "to get a more diffuse sound", as the manual describes it.
A lot of my listening it 2 channel music. The in-ceilings are only used for blu-rays.
logicology is offline
post #2 of 4 Old 02-23-2012, 11:30 AM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
Throw in some movies and experiment for what works/sounds best in your room. Take your time and enjoy with your final decision.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #3 of 4 Old 02-23-2012, 12:09 PM
underminded999's Avatar
Quoted: 29 Post(s)
I have my tweeters pointed towards the main listen position. Neither my Vife or I have any complaints.
I have the in-ceilings two feet away from the walls, and do not think pointing the tweeters away from the MLP would be beneficial.
underminded999 is offline
post #4 of 4 Old 02-23-2012, 12:53 PM
m_vanmeter's Avatar
Liked: 25
Dolby Labs recommends aiming the speakers at the listening position - the surround channels are mastered for positional audio sound effects and cues, so you want directional sound, not diffuse.
m_vanmeter is offline
