fuse size - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-23-2012, 01:34 PM - Thread Starter
83trekker's Avatar
Not sure if this is the right place to put this but i have a little canadian tire 400 watt power inverter and i want to wire it staright to my battery as the power wires that goto my cigarette lighter are so small i need a little more juice to the power inverter. What fuse size should i use for this inverter.
83trekker is offline
post #2 of 4 Old 02-23-2012, 01:38 PM
DonH50's Avatar
Quoted: 2105 Post(s)
Liked: 1667
400W/12V = 33.33 A. You probably want a little margin so maybe 35 - 40 A; there should be a sticker or note in the owner's manual (if you lost it maybe there's one online?).
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #3 of 4 Old 02-23-2012, 01:39 PM - Thread Starter
83trekker's Avatar
post #4 of 4 Old 02-23-2012, 03:28 PM
dknightd's Avatar
and you probably want to use 10 gauge wire.
Everything I say here is my opinion. It is not my employers opinion, it is not my wife's opinion, it is not my neighbors opinion, it is My Opinion.
dknightd is offline
