At what point do i need to worry about current draw from one electrical outlet? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 02-24-2012, 01:52 PM
Just cruising's Avatar
Originally Posted by WilliamZX11 View Post
I also said that I should not have used the word "most". I'm from the USA too, but in my area, we can read and understand English.
The NEC code is written in english!
Just cruising is offline
Old 02-24-2012, 02:22 PM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
Originally Posted by CatBrat View Post
You can always buy on of these kill-a-watt measuring devices.
http://michaelbluejay.com/electricity/measure.html
+1. They're cheap. $20-40 at Amazon, depending on the model: http://www.amazon.com/P3-Internation.../dp/B00009MDBU
It's REALLY doubtful there will be any issues whatsoever, unless that fish tank gear is especially beefy. (I agree, not a bad idea to move that to another outlet... although there's really no point unless that other outlet can be verified to be on another circuit)
If there's ANY concern, the kill-a-watt devices will measure actual, real-world draw of the entire system. Plug your power strip into the kill-a-watt, and crank the system to stupid levels, with everything going. You'll likely be surprised to see how little everything all running at once actually uses. A 15 amp circuit could most likely have been fine, unless there are a lot of other heavily-loaded outlets on the same breaker, and with a 20 amp circuit, there's pretty much no doubt there will be no issue.
Kalani is offline
Old 02-24-2012, 03:37 PM - Thread Starter
smfins's Avatar
Quoted: 36 Post(s)
Hey everyone.....How about my question regarding whether or not I can run a 3 channel amp across my front 3 speakers and still utilize the other 4 outputs for my surrounds? This can be done right? Thanks
smfins is offline
Old 02-24-2012, 04:52 PM
Speedskater's Avatar
Quoted: 20 Post(s)
The NEC code is just a rule book. It's not a law until a city or state makes it a law. That city or state if free to chose what year code-book to use (2003, 2005, 2008, 2011 or soon 2014). Each city or state is also free to delete parts or to add further restrictions.
Kevin
Speedskater is offline
Old 02-24-2012, 05:34 PM
DonH50's Avatar
Quoted: 1797 Post(s)
Liked: 1331
Yes.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
Old 02-24-2012, 06:16 PM - Thread Starter
smfins's Avatar
Quoted: 36 Post(s)
smfins is offline
Old 02-24-2012, 06:59 PM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
Absolutely, that's why 3 channel amps are popular. The good news is the rear 2-4 surround channels are a LOT less demanding, so your AVR should be able to push them no problem, while your beefier separate amp handles the more important LCR speakers.
Kalani is offline
Old 02-26-2012, 06:44 AM
whoaru99's Avatar
Liked: 69
You just want to be sure the amp is compatible with the impedance of your speakers when in the bridged mode.
Also, about all this power circuit stuff, circuit breakers aren't brick wall cutoff/limiters. A breaker will pass much more than its rated capacity for short durations that will cover very high peak demands. So, unless you're going to run continuous test tones through your system at WFO level, the breaker will see just high peaks not high continuous load.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
Old 02-26-2012, 06:49 AM
whoaru99's Avatar
Liked: 69
Originally Posted by KJSmitty View Post
For example: I run an AVR that can draw a max of 1200 watts, two subs totaling 600 watts and another two near 3000 watts. So total I could be looking at near 5000 watts considering the additional items/equipment. All on a dedicated 20 amp / 10 ga HT run (could go 30 amp if desired). Even at reference levels I have never seen it exceed 5 amps. Believe it or not, on average my living room 54 inch plasma and 5 channel system draws more under normal operation.
Afaik, per NEC, 20A is max you can connect to a general purpose lighting/receptacle circuit regardless that you have used 10ga cable.
whoaru99 is offline
Old 02-26-2012, 06:58 AM
KJSmitty's Avatar
Liked: 34
I don't think his plan is to "bridge" any amplifiers. He just wants to bypass the internal front three channel amps in his AVR with a dedicated three channel amp with more prowess. Then just utilize the AVR amps to run the side surrounds and rear channels etc. No bridging involved.. :-)
Cheers
Love DIY
KJSmitty is offline
Old 02-26-2012, 07:35 AM
KJSmitty's Avatar
Liked: 34
Thanks. I mentioned 30 amp given the dedicated 10 ga wiring - of which can be used for 30 amp circuits. Regardless, the way my dedicated circuit is run to the equipment area (and discussed via the electrician) I'm near positive it falls outside of the "general purpose" category. This circuit doesn't power a room of receptacles and lighting.. The room has two other 15 amp circuits for that.
I think we have muddy'd this thread enough with NEC / power chat myself.
Sorry OP.
Love DIY
KJSmitty is offline
Old 02-26-2012, 09:02 AM
kenglish's Avatar
Liked: 39
I would be more concerned with using a very good quality receptacle and good plugs, than anything else.
A good, commercial-quality receptacle is only a few dollars...plugs are similar. A tight connection will prevent overheating in the outlet.
I've seen melted (cheap) plugs and outlets in studios and editing bays.
Ken English, Sr. Engineer, KSL-TV.
"The postings on this site are my own and don't necessarily represent the Company positions, strategies or opinions."
kenglish is offline
Old 02-26-2012, 09:55 AM
whoaru99's Avatar
Liked: 69
Sorry OP.
Nothing wrong with using 10ga wire for less voltage drop.
However, IMO, merely because you use them as dedicated circuits doesn't permit 30A fusing under some type of clause regarding non general purpose application. If, for no other reason than the "Edison" type receptacles and plugs (5-15P/5-15R, 5-20P/5-20R, or the non-grounding 1-xxx variants) are only rated for 15A or 20A, not 30A.
whoaru99 is offline
whoaru99's Avatar
Liked: 69
Cheers
There was mention of six channel Rotel with those channels bridged to three.
Yes My receiver does have the pre outs, and i will check to see what my breakers are. Thanks for the info, and Like i said i have been looking at an Adcom 3 channel, but i also stumbled across a couple rotel 6 channel amps that can be bridged to 150x3. any other suggestions for 3 channel amps or bridgeable 6 channel amps?
whoaru99 is offline
Old 02-26-2012, 10:02 AM
KJSmitty's Avatar
Liked: 34
Good point, I only remembered his last post of the three channel Rotel.
Cheers
Love DIY
KJSmitty is offline
Old 02-26-2012, 10:14 AM
KJSmitty's Avatar
Liked: 34
Correct, you must utilize the appropriate NEMA connectors for the applicable circuit.
Cheers
Love DIY
KJSmitty is offline
Old 02-27-2012, 09:33 AM
underminded999's Avatar
Quoted: 29 Post(s)
Originally Posted by DonH50 View Post
... As Chris said, the initial current surge is primarily to charge the capacitors in the power supply and happens even if nothing else is hooked to the amp. Note that I have only had this issue rarely, and many (perhaps most) people not at all, so it is not something I would be too concerned about.
Have you used an AVR and an Amp on a "green" power strip? The initial influx makes since, and once the AVR(master) is on, the Amp(slave) would then draw whatever it needs for it's capacitors. What happens if the AVR is suddenly shut off, before the Amp could do everything it needs, would this damage the Amp?
I've been eyeballing these "green" strips for a while, but I am not sure if they do any harm. Also, if they don't do any harm, then it may be a good idea for the OP to use one, yes?
underminded999 is offline
Old 02-27-2012, 11:27 AM
whoaru99's Avatar
Liked: 69
A "green" power strip isn't going to save you one bit of power during normal use. What it will do is automatically kill the power to the amp and any other bits plugged into the switched outlets when the trigger device is shut off. Some devices always draw a little power when shut off. A green strip can help reduce that. However, it's not something you'd want to use with a device that requires AC to maintain memory/settings.
Some AVRs and amps already have the capability for remote switching capability.
The caps in an amp charge up pretty quick. This isn't a concern with regard to turning off the amp too soon.
whoaru99 is offline
Old 02-27-2012, 12:37 PM
DonH50's Avatar
Liked: 1331
What whoaru99 said.
I have a 750VA "green" UPS unit and my amps will trip its breaker when they turn on. I could turn them on manually, or stagger them with a little control unit, but they are now on a dedicated 20A line and I like them there. I use X10 appliance switches to turn them on, controlled by the AVR's 12V trigger through a little X10 transmitter unit.
My old tube amp would occasionally trip the breaker on a 15A power strip at turn-on.
I have not tried a SmartStrip; it would not work in my situation (amps on different circuit than AVR).
For a lot of reasons rapid power cycling of electronic componets (or most anything else) is not a good idea...
Old 02-27-2012, 02:08 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Excellent suggestion!
Available for $20 from Amazon.
Yet another piece of test equipment that used to cost $100s to acquire.
arnyk is offline
Old 02-27-2012, 02:35 PM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 690
late to this thread.......this comes up every 2 months or so, I advise people:
Check the back of your equipment or the owners manual (online for planning purposes)
It has this info, max current needs, here my EP2500 uses 9.5A @ 120V:
from my Denon 4308CI manual, (140w/ch 7 ch):
Power supply: AC 120 V, 60 Hz
Power consumption: 8.1 A
0.3 W (Standby)
add them up, be within 80% of the absolute load capacity of your circuit.
Some have said doing it this way you can go 100% of your circuit capacity, because each component in reality won't pull it's max load at same time, etc.
I error on safe side still for my circuit load analysis and usage.
mtbdudex is online now
Old 02-27-2012, 05:30 PM
tshep's Avatar
That and moving the fish to another receptacle/branch circuit/receptacle for their own safety were the 2 best posts in this thread.
On a $.29 duplex there is just a small bit of spring pressure making the plug connection - heat it once and it's gone! Try a $3 receptacle at HD with a borrowed plug and see the difference. Then add a good, tight strip for all the other connections - well spread out.
tshep is offline
Old 02-27-2012, 06:01 PM
whoaru99's Avatar
Liked: 69
0.3 W (Standby)
Yeah, those numbers are valid if you're running the system WFO with the clipping indicators flashing to about every third beat. In typical use the average draw will be less except perhaps on big peaks, which the inherent time lag of breakers will easily handle.
whoaru99 is offline
Old 02-29-2012, 04:46 PM
DoyleS's Avatar
Quoted: 35 Post(s)
Liked: 25
Here is a handy little digital meter that you can use to check current draw as well as power in watts for about $20. Plug your power strip into it and turn all the instruments on and you can read the total power or current.
M&K S150THX LCR, SS150THX Tripoles, 4 Speakercraft Aim-7 for Atmos
B&K AV5000 driving the M&Ks
Denon X4300H AVR
"So many tweeks....So little time!"
DoyleS is offline
Old 02-29-2012, 05:18 PM - Thread Starter
smfins's Avatar
Quoted: 36 Post(s)
Thx for the info!!!
smfins is offline
Old 02-29-2012, 06:47 PM
whoaru99's Avatar
Liked: 69
It'll show a pretty small number unless you're running test tones because it's too slow to show peaky audio demands.
whoaru99 is offline
Old 03-03-2012, 02:31 PM
Quoted: 20 Post(s)
Yes the meter looks at current draw in a way that's similar to the way breakers and wires view current draw.
Neither the meter nor the breaker over-reacts to short peaks.
Kevin
Old 03-03-2012, 09:49 PM
KJSmitty's Avatar
Liked: 34
For a reference point,
I actually performed a bit of a test tonight. Kids wanted to watch the Green Lantern tonight so prior to them sitting down I closed up the HT and cranked the AVR to -10. Played about the first 10 minutes of the movie which is pretty dynamic This is the loudest I can see us ever watching a movie. Awhile back I claimed only seeing between a 4 and 6 amp draw on my system. I watched it closely tonight and with an AVR that can draw 1200 watts, four subs totaling 3600 watts and about 600 watts of projector, cooling fans, BD, HD, power regulator and conditioner etc., it peaked at 9.8 amps. I was also running the subs hotter than normal. 9.8 was the peak yet it ranged from 4 to 8 amps the entire time.
Cheers
Love DIY
KJSmitty is offline
Old 03-04-2012, 12:29 PM
AV Doogie's Avatar
What type of meter was used to measure the current magnitudes? Sorry if I missed that info.
My Home Theater Site:
DJ-Theater
AV Doogie is offline
Old 03-04-2012, 12:48 PM
KJSmitty's Avatar
Liked: 34
Just the display on an AVS2000 and HTPS7000. Have no idea how accurate they are, the 7000 is definitely more sensitive and quicker to respond than the 2000. The 2000 looked as if it was just averaging the current draw and the 7000 was actually fluctuating constantly. Volt wise using a meter both units/displays are within a half of a volt. Not sure if the amp reading is as accurate or not.
Edit: my watt use per component is based off the specifications info in the manual - maximum load etc.
Cheers
Love DIY
KJSmitty is offline
