Question about adding an AMP to a 5.1 to 7.1 receiver - AVS Forum | Home Theater Discussions And Reviews
Old 02-26-2012, 03:32 AM - Thread Starter
joejack11's Avatar
I'm curious about an idea i had, I'm sure it was probably posted before.
Anyway.
Lets say you got a 7.1 receiver, and it was Pre amp outputs, can you pair that with an Amp, says say Front left & right, so now the amp, you add 2 speakers to it,
making it so theres 9 channels of sound from 9 speakers?
or is my idea busted?
joejack11 is offline
Old 02-26-2012, 05:38 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
Anyway.
9.1 isn't made by duplicating front left and right, its often made by adding side channels.
Here's a little mind experiment. If I take a single mono channel and duplicate it, do I have stereo? What you seem to be proposing to do is the same thing, only with more channels to start with.
arnyk is offline
Old 02-26-2012, 09:49 AM
commsysman's Avatar
Quoted: 980 Post(s)
Liked: 526
The reason most people add a power amplifier to a receiver is to get more total audio power.
Many receivers don't have a big enough power supply, and the power available for each channel may drop down to 40 watts or so when all channels are driven.
By adding a stereo power amplifier to drive the front channels, the receiver has two less channels to drive and can do a better job with the rest.
Of course, you can't do this unless your receiver has preamp outputs for the front 2 channels, which many do not have.
There is very little source material that has been properly recorded or mixed for more than 5 channels, so the value of anything beyond 5 channels is a debatable issue.
It is also worth considering whether to spend money on more than 5 channels or whether to spend the same amount of money buying better speakers for the most important 5 channels.
Anyway.
commsysman is offline
