what's the minimum surge protection i need ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-12-2012, 10:52 PM - Thread Starter
danny_isr's Avatar
Ok i'm new into this.
i got a new system (power amp Rotel 1095 , receiver , CD player , PS3 ,TV).
what kind of surge protection i need ?
i went to Radio Shack and lowes and saw many kinds of surge protection.
Are those good enough ? if not then what is the minimum i need ?
thanks
BP - Sony BDP-S5100 PreAmp - Marantz AV7005 PowerAmp - Rotel RMB - 1095
Main - Dynaudio Focus 220 MKII Center - Dynaudio 200c Sub - Paradigm DSP-3200 Rear Mission SC-5MK
danny_isr is offline
post #2 of 5 Old 03-12-2012, 11:42 PM
whoaru99's Avatar
Liked: 69
Do you own your house? If so, I'd look into a whole house surge unit from Leviton, Eaton, et al., that connects into the breaker box.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
post #3 of 5 Old 03-13-2012, 02:49 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Depends on what the power is like where you live. If you live in an urban area, you probably need no added surge protection. If you live in a suburban or rural area, you may need surge protection to guard against near hits by lightning. Then you need a a whole-house surge protector that is usually installed by an electrician.
arnyk is offline
post #4 of 5 Old 03-13-2012, 07:40 AM
AV Doogie's Avatar
A good place to start is with a basic understanding of suppression and its application to residential equipment.
http://www.eaton.com/Electrical/USA/...TVSS/index.htm
Click on the above and go to the Products Aids section....then click on Guides to Surge suppression.
My Home Theater Site:
DJ-Theater
AV Doogie is offline
post #5 of 5 Old 03-13-2012, 03:59 PM - Thread Starter
danny_isr's Avatar
thanks for the info , good stuff.
i do own my house , and i do live in suburban area. So sounds like i need a "house system", So i will probably go that route .
Maybe i will get a simple surge power strip as temporary solution.
