AVR crossover setting question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-22-2012, 02:28 PM - Thread Starter
jsgrise's Avatar
Quoted: 171 Post(s)
Liked: 68
Here are my my speakers frequency response:
Center: 85Hz - 23KHz
Main: 50Hz - 23 KHz
Surrounds: 83Hz - 23KHz
+/- 3 dB
What should be the crossover wetting in my AVR? 100Hz? I don't have advance x-over allowing me different crossover to accommodate each channel.
Dedicated HT | DUAL 18" Dayton RSS460HO Custom Build | Sonus Faber Venere 1.5s | Sonus Faber Venere Centre | Sonus Faber Venere Walls | Marantz SR-7010 | Behringer iNuke 6000DSP | Velodyne SMS-1 | JVC D-ILA RS-46 w/ 128" 16:9 1.4 | Custom Bass Traps and Acoustic Panels (11)
jsgrise is offline
post #2 of 4 Old 03-23-2012, 06:46 AM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
Do you have a sub? If so, THX suggest you set the crossover at 80hz and set the speakers to small so that all the sound 80hz and below goes to the sub. You dont want the crossover set too high or else you could get some dialog and other asound you dont want in the sub showing up in the sub.
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #3 of 4 Old 03-23-2012, 07:08 AM
flickhtguru's Avatar
Liked: 110
That's the short comings of having a receiver with only 1 xover point.
I would try 80hz (no lower) if 80 doesn't sound good then try 100hz.
If you go above 80hz I recommend having the sub as close to the center and mains as you can so its not so localizable.
Shawn
flickhtguru is offline
post #4 of 4 Old 03-23-2012, 12:34 PM
walbert's Avatar
I'd take a stab at 100hz, or (if the receiver lets you), 90hz.
Does your receiver let you do any sort of auto-setup routine? Also, I'm assuming this is the theater in your sig-link? Is the SMS-1 setup properly?
walbert is offline
