HK AVR 158 auto detect problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-28-2012, 12:11 PM - Thread Starter
username80's Avatar
Hello,
My Harman Kardon AVR 158 receiver is conected to my computer with optical SPDIF cable.
The receiver able to detect DTS and Dolby Digital just fine, but my problem is when i pause the movie the Display on the receiver change from DTS/DD to PCM and when i play the movie again it change back to DTS/DD.
Each time there is such change there is a sound of electrical power surges from the speakers.
It looks like that signal is changing when pausing the movie.
Can someone please advise how i should fix it? Is there any special set up i should do?
I have windows XP with on board sound card.
I will appreciate your help as this is driving my crazy.
Thank you
username80 is offline
post #2 of 4 Old 03-28-2012, 01:47 PM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
Engage "mute" on the AVR before pausing the movie. Turn "mute" off on the AVR when the movie has been restrarted.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #3 of 4 Old 03-28-2012, 02:29 PM - Thread Starter
username80's Avatar
Thank you Ratman.
I was thinking that there would be other solution for that.
I did a small research and apparently this issue is very common as "spdif pause bug", but i didn't find any solution that works.
If someone know how to fix this problem i am sure it will help others as well.
post #4 of 4 Old 07-18-2013, 08:53 AM
Martial Ahmed's Avatar
bonjour je voudrai savoir comment avoir le son de ma tele sur mon ampli mad.gif
Martial Ahmed is offline
