Help with new Home Theater setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 04-01-2012, 11:42 AM - Thread Starter
dunnmike's Avatar
Hi, I have a new home theater set up. I wish I had known about this forum before i purchased parts. Right now I have Rc85i front speakers in wall, Cs10 center, Rc80i rear in ceiling speakers, sony sw10 sub, and an AVR-1612 denon receiver powering it all. I have it set up decently but when playing music it seems a bit sharp. I know there are settings that i could adjust to warm up the sound but the denon avr manual is generic. Any help would be appreciated. Thanks again.
dunnmike is offline
post #2 of 14 Old 04-06-2012, 11:16 AM - Thread Starter
dunnmike's Avatar
Bump
dunnmike is offline
post #3 of 14 Old 04-06-2012, 12:57 PM
Ethan Winer's Avatar
Quoted: 264 Post(s)
Liked: 359
Saying the sound is "sharp" doesn't really explain much. I can tell you that room acoustics and untamed reflections are a major cause of poor sound quality:
Acoustic Basics
--Ethan
Ethan Winer is offline
post #4 of 14 Old 04-06-2012, 03:17 PM - Thread Starter
dunnmike's Avatar
The highs are piercing in the top frequencies 10kish and up. If I adjust the tone it affects the whole "treble" frequency ranges. I want to be able to adjust the treble to a nice level. I had a different avr hooked up and it has an eq built in that had manual adjustments but it's old and doesn't have hdmi. I was able to fine tune the speakers with that avr to a fantastic sounding system. Maybe this new denon 1612 avr needs an upgrade?
dunnmike is offline
post #5 of 14 Old 04-06-2012, 06:54 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
Did you run Audyssey? If not, that can help correct for issues with room acoustics and might solve your problem.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #6 of 14 Old 04-06-2012, 08:24 PM - Thread Starter
dunnmike's Avatar
Yes that was the first thing I did. I did have to adjust the settings for speaker DB as it was way off. I have put hardwood flooring in and ran the audyssey setup again after resetting the microprocessor. I like the movies but can't stand how the music sounds at a relatively high volume. Is there a way to adjust the frequencies via the avr, or is there an avr on the market that will allow me to make the adjustments I want to make the sound better?
dunnmike is offline
post #7 of 14 Old 04-06-2012, 11:11 PM
derrickdj1's Avatar
Quoted: 887 Post(s)
Liked: 598
I wonder if you are pushing that avr to hard. HF increase several db in relationship to the bass when avr's are under strain. You may just need more headroom.
derrickdj1 is online now
post #8 of 14 Old 04-07-2012, 10:13 AM - Thread Starter
dunnmike's Avatar
So like a good amp to eliminate distortion near higher volumes?
dunnmike is offline
post #9 of 14 Old 04-07-2012, 01:08 PM
Quoted: 264 Post(s)
Liked: 359
Originally Posted by dunnmike View Post
Yes [running Audyessey] was the first thing I did.
Have you also tried disabling Audyssey to see if the sound improves? Again, harshness is often due to untamed early reflections from the side walls and ceiling.
--Ethan
post #10 of 14 Old 04-07-2012, 01:40 PM - Thread Starter
dunnmike's Avatar
I did and it was ok but not great. I did notice being unhappy after I put wood flooring in. What would you suggest besides an area rug. This is in my living room, so any suggestions for wall treatments? The room has flat ceilings and laminate flooring. Any help would be great.
dunnmike is offline
post #11 of 14 Old 04-08-2012, 12:37 PM
Quoted: 264 Post(s)
Liked: 359
The Acoustic Basics article I already linked to earlier is a great place to start.
--Ethan
post #12 of 14 Old 04-08-2012, 01:08 PM - Thread Starter
dunnmike's Avatar
Sorry I overlooked the link but thank you for the information! I'll definitely look into it and see what I can do before I change any configurations!
dunnmike is offline
post #13 of 14 Old 04-08-2012, 01:11 PM
pokekevin's Avatar
Liked: 102
Post pics of your layout so we can better help. Also how did you run audyssey?
pokekevin is offline
post #14 of 14 Old 04-08-2012, 02:59 PM - Thread Starter
dunnmike's Avatar
I have to in walls right next to the tv on each side. The center chan is right below the receiver and the ceiling rears are above the couch. Unfortunately the only place for the couch is near the rear wall. I'll post pics soon as I get a chance. I ran audyssey with the mic on a dining room chair at ear level at the three optimal seating spots. I used the chair as I didn't have a tripod to put it on. I have tweaked the settings a bit as the db's seemed to be off per speaker. I assume from the lack of acoustic treatment and the new flooring. I still at high volumes, wish that I had more control over the higher frequencies.
dunnmike is offline
