Frequency Response Question - AVS Forum | Home Theater Discussions And Reviews
Old 04-07-2012, 04:19 PM - Thread Starter
Joe111Black's Avatar
I currently own the Polk Audio TL-250s but I am having a bit of trouble understanding what the proper cutoff frequency should be for these. The specs show that they have an overall frequency response of 90Hz and a lower -3dB limit of 120Hz.
I currently have them set at 90HZ but I believe that this may be mistake on my part as I am still learning new things about home theater settings. Should I be adjusting according to the overall frequency response or the 3db limit?
Kind Regards
Joe
Joe111Black is offline
Old 04-07-2012, 04:46 PM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
as far as i am concerned you should cut off at the -3db point or a bit higher. for those speakers 120hz-150hz is what i would try. but as always let your ears be your guide with your gear in your room.
I don't need snobs to tell me how to think, thank you!
67jason is offline
Old 04-07-2012, 04:56 PM - Thread Starter
Thank you for your insight
walbert's Avatar
Kind Regards
Joe
What receiver do you have (and subwoofer for that matter), and does it have an auto calibration feature? If so, what does that feature want to pick?
Ideally your LF xover is above the -3 dB, to prevent dips in the system FR, but the room and placement will influence overall FR beyond what the anechoic numbers from Polk can tell us. In other words, the ideal crossover point may be different than what the specsheet would indicate.
With such small satellites, they're likely ideally crossed at some much higher frequency, but that may cause integration problems with the subwoofer.
walbert is offline
