Need to connect 2 speaker wire to 1 RCA help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-25-2012, 12:43 PM - Thread Starter
oppi's Avatar
OK let me set the stage for this question, the new TV i am looking at is the mitsubishi WD73840. It has 16 speakers which can either do all your sound or be your center channel. The TV has a single rca plug for center channel input (not a pair of plugs red/white just one hole) Now my receiver can only output the center signal as bare speaker wire or banana plugs. How can i send the 2 wire signal of the receiver to the single rca input?
the back panel is on pg 9 of this manual link
thanks stumped
Dan
oppi is offline
post #2 of 7 Old 04-25-2012, 12:51 PM
rdgrimes's Avatar
Quoted: 2343 Post(s)
Liked: 1675
You can't. It requires a line-level output from the receiver, not speaker-level.
rdgrimes is online now
post #3 of 7 Old 04-25-2012, 01:27 PM
JHAz's Avatar
Quoted: 307 Post(s)
Liked: 274
True, unless you buy a speaker-to-line level converter. Common in car installations. Searching speaker to line level on yahoo pulled up a bunch on Ebay, some as cheap as $8.00. I can't say whether any are superior or inferior.
JHAz is offline
post #4 of 7 Old 04-25-2012, 01:32 PM
chikoo's Avatar
What receiver?
chikoo is offline
post #5 of 7 Old 04-25-2012, 02:45 PM - Thread Starter
oppi's Avatar
Harman kardon avr 145
oppi is offline
post #6 of 7 Old 04-25-2012, 04:56 PM
chikoo's Avatar
WD-73840 Owners Manual
13. CENTER INPUT
840 Series. Connect your A/V receiver’s center
channel output to this input to have the TV speakers
complement your external sound system with
center-channel sound. Set Sound > Global > Center
Channel to On to enable this input. See “Using the TV
Speakers as a Center Channel,” page 16 .
Using the TV Speakers as a Ce nter
Channel
If using an external surround sound system, you can
use the TV’s speakers to provide center channel sound.
Your A/V receiver must have a center channel pre out
that can supply an amplified center-channel signal to
the TV
HK AVR 145 Back Panel
No PRE-OUT on the HK AVR 145.
But what is confusing is that the TV manual states it requires "an amplified center channel signal". Whoa.
chikoo is offline
post #7 of 7 Old 04-25-2012, 08:19 PM - Thread Starter
oppi's Avatar
thanks for all the help folks, I haven't posted much but i read a lot and you all answer a lot of questions and provide solutions for stuff. I love this place
Guess I either need a new receiver or I can downgrade the level of the TV a bit to the 740 since the big add on the 840 is the 16 speakers in the front that can be used as a center channel. I can use my JBL S Center for that and prob get better sound
Dan
oppi is offline
