Side surround speaker placement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-30-2012, 10:18 AM - Thread Starter
cmryan821's Avatar
Quoted: 202 Post(s)
Liked: 66
Guys, I'm trying to come to a decision on my surround speakers and I was hoping for some guidance. I cannot wall mount any speaker on my left wall because of a built-in cabinet already in my living room. I'm posting a pic of the rear left wall. When seated, our ears are pretty much in line with the edge of the mantle which is barely in the pic. I figure I have three choices and each has a potential shortcoming:
1) I can mount a dipole/bipole on the rear wall but they would be facing directly forward and outside of the 90-110 degree area recommended for side surrounds.
2) I can use a ceiling mount to suspend a dipole/bipole or bookshelf angled downward and slightly back while staying within the 90-110 degree area, but I have a 10' ceiling so this would place them much higher than the recommended couple feet above ear height.
3) Just place bookshelves or a dipole/bipole on stands and try to get them a little above ear height. This would put me right at the edge of the 90-110 degree area but perhaps not high enough.
I'm leaning towards option 2 or 3 but I am VERY open to suggestions, and I'd really appreciate any help.
Edit: This is a link to a full room layout in case my description is too confusing. Also, this is for a 5.1 setup so there would not be any rear speakers.
cmryan821 is offline
post #2 of 9 Old 05-01-2012, 07:41 PM
Espo77's Avatar
Quoted: 183 Post(s)
Liked: 85
You could place the speaker on top of the built in, or on the shelf just above the drawers...where the pictures are.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #3 of 9 Old 05-01-2012, 08:05 PM
Jim McC's Avatar
Quoted: 194 Post(s)
Liked: 69
Assuming it's a 5.1 system, I would put Bipoles on the rear wall. That's how mine is set up.
Jim McC is offline
post #4 of 9 Old 05-01-2012, 08:15 PM - Thread Starter
cmryan821's Avatar
Quoted: 202 Post(s)
Liked: 66
Thanks for the suggestions. I'd considered placing on top of the built-in but it would get kinda tricky up there. The top of the cabinet's trim is raised about 4" above the top of cabinet itself so if I placed a surround there it would need to go on a stand. Also, since I took that pic I've placed a bass trap on top of the cabinet on the advice of some acoustics guys. So on top of the cabinet presents some problems.
As far as the shelf placement, I guess it would be similar effect to option three, and snaking a speaker wire from behind the wall and through the cabinet would hide the wire effectively. Just need to make sure I get a white speaker, but that wouldn't be too much of a problem. Thanks again for your time.
post #5 of 9 Old 05-01-2012, 08:16 PM - Thread Starter
cmryan821's Avatar
Quoted: 202 Post(s)
Liked: 66
So bipoles facing straight forward wouldn't compromise the surround effect? I was under the impression that they had to be aimed roughly at the main listening spot. Well, the middle of bipoles(not the actual drivers) had to be aimed at the listening spot.
Edit: Yes it is a 5.1. Should have included that in my first post. Sorry.
post #6 of 9 Old 05-01-2012, 11:27 PM
Jim McC's Avatar
Quoted: 194 Post(s)
Liked: 69
Dipoles need to be mounted in-line with your ears, when seated. Not bipoles. Bipoles on the rear wall work great for me.
Jim McC is offline
post #7 of 9 Old 05-02-2012, 09:46 AM - Thread Starter
cmryan821's Avatar
Quoted: 202 Post(s)
Liked: 66
Alright. Just when I think I have a good understanding of speakers I learn that I still don't know anything. I guess I need to look into finding bipoles specifically. If you don't mind me asking, which brand and model did you go with?
post #8 of 9 Old 05-02-2012, 11:56 AM
Jim McC's Avatar
Quoted: 194 Post(s)
Liked: 69
Mine are "Energy" bipoles, but they are discontinued. I bought them a couple years ago. I would ask for recommendations in the Speaker section.
Jim McC is offline
post #9 of 9 Old 05-04-2012, 06:13 AM - Thread Starter
cmryan821's Avatar
Quoted: 202 Post(s)
Liked: 66
Thank again. There's a few I have in mind now(Klipsch rs42, Deftech BPX and axiom qs8) so I guess I need to get them in house and try them out as best I can.
