Stupid question regarding speaker wire... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 206 Old 04-30-2012, 02:01 PM - Thread Starter
gizzygone's Avatar
Quoted: 71 Post(s)
Hello all,
Just a quick question about speaker wire. I bought some audio quest in wall speaker wire for my new surround sound system. I noticed there are arrows on the shielding... Is speaker wire directional, or is that decoration on the jacket?
gizzygone is offline
post #2 of 206 Old 04-30-2012, 02:13 PM
SAM64's Avatar
Liked: 78
It's probably to indicate which conductor is which.
Cables are not directional.
Insulation is not the same as a shield.
SAM64 is offline
post #3 of 206 Old 04-30-2012, 02:48 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
Speaker wire is not directional, but the arrows aren't just for decoration. They're there to fool you into thinking that Audioquest wire is better than other wires because it is directional.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #4 of 206 Old 04-30-2012, 04:23 PM
krazedj's Avatar
AudioQuest tests out the resistance on both ends of the cable. The end direction that has the least amount of resistance is the direction that the arrows point in. Arrows go from the source (Blu-ray player) to either your display device (TV), or Audio Device (AVR).
Do or do not. Try, there is no try.
krazedj is offline
post #5 of 206 Old 04-30-2012, 04:37 PM
DonH50's Avatar
Quoted: 2096 Post(s)
Liked: 1662
That's a joke, right?
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #6 of 206 Old 04-30-2012, 04:58 PM
ccotenj's Avatar
Liked: 101
i HOPE it is...
but, sadly, i think he is serious...
- chris
ccotenj is offline
post #7 of 206 Old 04-30-2012, 05:00 PM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #8 of 206 Old 04-30-2012, 05:05 PM
Ivan Beaver's Avatar
Quoted: 16 Post(s)
Liked: 59
If you have ANY resistance on EITHER end-YOU have a problem.
If you hook a meter between the terminals-it should read an open (ie VERY high resistance).
But like others I really hope you are just kidding and trying to get people "excited".
Danley Sound Labs
Physics-not fads
Ivan Beaver is offline
post #9 of 206 Old 04-30-2012, 05:22 PM
holt7153's Avatar
Quoted: 139 Post(s)
Liked: 221
Just make sure you don't connect them backwards--ambient sounds in your house from garbage disposals or air horns will be fed through your speakers and could overload your AVR .
Sammy2 likes this.
Anything good in life is either illegal, immoral, or fattening.
holt7153 is online now
post #10 of 206 Old 04-30-2012, 05:39 PM
jproy13's Avatar
Liked: 26
For real? could it also cause my BD player to clip?
jproy13 is offline
post #11 of 206 Old 04-30-2012, 05:42 PM
William's Avatar
Quoted: 29 Post(s)
Liked: 50
Actually they ask the electrons which way feels better to them and then line the atoms up in the cable (one by one) so the electrons are happy. Happy electrons = superior sound.?
William is offline
post #12 of 206 Old 04-30-2012, 05:43 PM
jproy13's Avatar
Liked: 26
that is kind of like saying that the arrow on my garden hose is for showing the path of less restrictive water flow. I better go check if it's hooked up correctly, wouldn't want the water to come out of my neighbor's tub when I want to water my lawn
for the record, there is no arrow on my garden hose
jproy13 is offline
post #13 of 206 Old 04-30-2012, 05:44 PM
jproy13's Avatar
Liked: 26
he he, I like your analogy better
jproy13 is offline
post #14 of 206 Old 04-30-2012, 06:04 PM
DonH50's Avatar
Liked: 1662
For optimal electron alignment in my listening room I use my Tice clock.
DonH50 is offline
post #15 of 206 Old 04-30-2012, 06:32 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4779
I was curious just what specs they might sell this stuff with so a googling I went and found this in the Crutchfield ad. When I first saw the sequential footage markers I thought maybe that's it, but then the next line squashed that. I think the best feature is the last one listed:
14-gauge, 4-conductor cable (14/4)
UL-rated for in-wall installation
rated for direct burial
high-purity copper for high-integrity signal transfer
Concentric Pack stranding ensures high conductivity and low distortion
twisted pair construction combats interference
sequential footage markers printed on jacket for accurate cable measurements during installation
directional arrows tell you which way the signal should flow for the best sound
warranty: 5 years
Our 60-day money-back guaranteee.
If you're going to run inwall why would you want four wires? You always plan on co-locating speakers? Or bi-wiring/bi-amping?
lovinthehd is offline
post #16 of 206 Old 04-30-2012, 06:49 PM
gregzoll's Avatar
Liked: 33
Really? I never knew that. I thought that the arrows were there as a way to tell dust bunnies which way to migrate, to make more dust bunnies.
What other wisdom do you have for everyone?
gregzoll is offline
post #17 of 206 Old 04-30-2012, 07:01 PM
lovinthehd's Avatar
Liked: 4779
Maybe he's just a kraze dj...or being sarcastic.
That's pretty funny that they would test each wire and mark 'em! Marketing does work! The bonus that you can use your speaker wires to connect your components as well is pretty good, too...
post #18 of 206 Old 04-30-2012, 07:13 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
Bunnies do not need to be told how to make more bunnies.
mcnarus is offline
post #19 of 206 Old 04-30-2012, 07:19 PM
gregzoll's Avatar
Liked: 33
Tell me about it. We seem to always find a second or third Golden Retriever in our house, when we vacuum, at least twice a week.
gregzoll is offline
post #20 of 206 Old 04-30-2012, 07:23 PM
gregzoll's Avatar
Liked: 33
lovinthehd, only place that the arrows really matter, is with stuff like Diodes, etc, filters for liquid agents, etc, or when marking pipes for flow, so that when people are trying to trace the route, even though they have blueprints or schematics, they may not have them at that point.
Never really in my life of handling hundreds, if not thousands of various gauges of wire, from everything from wire wrapping, to hauling huge Ship to Shore power lines, has there ever been an arrow on that. Now of course, if some joker decided they wanted to pull one over on the new guy, yes we would take some length and mark it, to see if they would catch it.
gregzoll is offline
post #21 of 206 Old 04-30-2012, 07:27 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
And don't forget: They charge more for the wire with the arrows.
mcnarus is offline
post #22 of 206 Old 04-30-2012, 08:32 PM
chikoo's Avatar
I am getting more laughs at avs forums than comedy central !!!!
chikoo is offline
post #23 of 206 Old 04-30-2012, 09:13 PM
lovinthehd's Avatar
Liked: 4779
Yer preachin' to the choir as they say. I was just curious what bs those trusty folk in sales/marketing might come up with and just to see what the product actually was.
post #24 of 206 Old 04-30-2012, 10:25 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
You obviously do not have an AudioQuest garden hose.
domino92024 is offline
post #25 of 206 Old 04-30-2012, 10:32 PM
mirkolop's Avatar
I have very old speaker wires. There is some green discoloration in one of them. It is clear and I can see the green going a ways. what is it? Should I think of replacing? It is thick wire, I think 10 gauge, maybe 12. Thicker than lamp cord. The only problem is that they run through a built in cabinet. They may be a PIA to replace. If my speakers still sound good, should I worry about it?
mirkolop is offline
post #26 of 206 Old 04-30-2012, 11:37 PM
dragonfyr's Avatar
Originally Posted by gizzygone View Post
Hello all,
Since you have not been more specific with the precise cable topology, such as between twin conductor or coaxial variants (although I would normally assume a twin lead for regular full range speakers...), it may indicate neither 'electron directivity' - where electron drift measured in inches/feet per second and is not a significant factor in signal flow, considering that the signal is actually carried by an EM field..., nor some imagined difference in resistivity; but rather another more practical factor.
It can very possibly indicate that while "normal" cables can incorporate an outer circumferential shielding that is connected at both terminating fittings, that in order to reduce ground loops and the associated hum, that one end of the sheathing is disconnected (unterminated). thus the arrows indicate the recommended orientation of the cable and the terminated fitting(s).
Not an optimal solution, but it can work to a limited degree.
So in some cases there is a manner of reasoning behind the concept of a 'directional' cable. But even with such cases considered, I fear you (and to many in the market as a whole) are being influenced more by the marketing techno-babble, appearances and suggestive rationalization than to any objectively determined actual behavior in a product niche where significant profit margin exists, and where vendors count on such accessory sales to constitute a inordinately large and significant percentage of their actual profits.
dragonfyr is offline
post #27 of 206 Old 05-01-2012, 03:45 AM
William's Avatar
Quoted: 29 Post(s)
Liked: 50
Do you know how much it's costs to print arrows on the casing? Also after testing a them a large percentage are rejected because the arrows were printed in the wrong direction and they will short out your amp/speakers.
Also they can't print the arrows before testing because the cables can change direction and it becomes fixed after printing.
William is offline
post #28 of 206 Old 05-01-2012, 04:26 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1241
If they are printing anything else on the wire, adding the arrows costs next to nothing.
I don't think there's much danger of the printing going on wrong, since the wire itself is fully bi-directional. ;-)
Testing? Do tell how one tests copper wires for their preferred direction of conduction!
Dowsing rod?
Inspection of goat entrails?
Observe splatters of chicken blood?
arnyk is offline
post #29 of 206 Old 05-01-2012, 04:34 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1241
If the wires didn't get green until you had them for a long time, I'd replace them immediately because they must be slow wires. Some of the wire I've had turn green did so quite quickly, which indicates that they give "fast bass". ;-)
Seriously, the green color is probably due to a very thin layer of copper sulfate or other copper compound forming on the surface of the wire. Sulfur r comes from either the atmosphere or from the insulation. If it happens along the length of the wire, then the insulation is the most probable source. If it happens only at the ends, then the atmosphere is the most probable source.
Other than making the wire hard to solder and very much in need of cleaning at the ends before you reconnect them to equipment, it has no electrical effects.
Basically its corrosion. In a few hundred years it might have some effect on how the wire conducts signals.
The only reason I can think for replacing this wire is aesthetics. If you foresee a visit by the wire police, then you may want to change them out. The corrosion might be very detrimental to bragging rights.
arnyk is offline
post #30 of 206 Old 05-01-2012, 05:45 AM
Swampfox's Avatar
Quoted: 18 Post(s)
It's actually the direction of the ch'i.
So if you want your music to 'go with the flow' you make sure it's oriented in the right direction. Unless, of course, it's death metal, then you probably want to hook it up backwards.
Swampfox is offline
