For this room size (pic included), can I make wall-mounted surrounds work? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-09-2012, 12:12 AM - Thread Starter
pr0crast's Avatar
Obviously the TV goes on the rightmost wall. But where should the surrounds go to get the best sound for movies? On the wall, or in the ceiling? From everything I've read, in-ceiling speakers tend to be a compromise.
pr0crast is offline
post #2 of 8 Old 05-09-2012, 12:51 AM
Jim McC's Avatar
Quoted: 157 Post(s)
Liked: 64
If the TV is on the far right wall, I see no wall for the right surround speaker. Am I missing something?
Jim McC is offline
post #3 of 8 Old 05-09-2012, 01:01 AM - Thread Starter
pr0crast's Avatar
On the south wall where you're looking, there's a coat closet and a pantry. Above the doors for those there is wallspace.
pr0crast is offline
post #4 of 8 Old 05-09-2012, 02:19 PM
Jim McC's Avatar
Quoted: 157 Post(s)
Liked: 64
It's hard to tell from that drawing, but probably on the left and right walls. How far from each speaker would you be when seated?
Jim McC is offline
post #5 of 8 Old 05-09-2012, 09:12 PM - Thread Starter
pr0crast's Avatar
I found a video I took on my phone of an open house a few months ago with the same floor plan as the house I ended up buying (but a mirror image). You can catch a couple glimpses of the areas in question.
Someone else recommended to me the bipole/dipole Verus speakers since those are designed to be wall-mounted and blend pretty well with the Verus Grand fronts/center, which I'll be buying. Do you think it would work if I placed those above the closet and sliding glass doors, on the left/right walls?
pr0crast is offline
post #6 of 8 Old 05-10-2012, 12:22 AM
Jim McC's Avatar
Quoted: 157 Post(s)
Liked: 64
Yes. I use bipoles for my surrounds.
Jim McC is offline
post #7 of 8 Old 05-13-2012, 06:02 PM - Thread Starter
pr0crast's Avatar
Jim, do you think there's any value to 7.1 in this room? Also considering that if I did do 7.1 the last two speakers would have to be in-ceiling.
pr0crast is offline
post #8 of 8 Old 05-14-2012, 12:48 AM
Jim McC's Avatar
Quoted: 157 Post(s)
Liked: 64
If they had to go in the ceiling, I would not do it. Stick with 5.1
Jim McC is offline
