When doing an Auddessy config on a Denon - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-11-2012, 06:40 AM - Thread Starter
Roachforlife's Avatar
Quoted: 26 Post(s)
Does it matter if I run thru the setup with the mic and THEN change the speakers to small? Or must I set them to small first before doing the microphone test thing?
Sorry if dumb question
thanks
Roachforlife is offline
post #2 of 5 Old 05-11-2012, 06:46 AM
BillCinLR's Avatar
This thread will answer EVERYTHING:
http://www.avsforum.com/avs-vb/showthread.php?t=795421
Bill C
BillCinLR is offline
post #3 of 5 Old 05-11-2012, 06:46 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
Run the auto-cal then check what the receiver has set the speakers to, if large change to small and set cross over to what ever you need it to be, usually 80hz.
changing the large/small settings, crossover settings, speaker trim levels does not effect the auto cal equalization.
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #4 of 5 Old 05-11-2012, 07:45 AM
ccotenj's Avatar
Liked: 101
one clarifying note...
xover settings, as long as you do not lower them, do not effect the calibration...
- chris
ccotenj is offline
post #5 of 5 Old 05-11-2012, 11:37 AM - Thread Starter
Quoted: 26 Post(s)
thanks all!
