RS-232 to wireless: Can you control your AVR through this port? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 05-11-2012, 06:48 AM - Thread Starter
Not the Momma!'s Avatar
I have an odd question regarding my Marantz SR5005.
I have the model before they started putting Ethernet ports in the back and making them network capable. (Bummer right?)
I was wondering a few things.
1. The RS-232c port on the back; can it be used to control the AVR with these commands:
Power on
Power off
Volume Up
Volume Down
Mute On
Mute Off
Source Select Up
Source Select Down
2. If you can do that, could you get a RS-232c 9 pin to Ethernet or wireless connector so I can control them through an app like iRule. (I know they make these converters)
So am I asking for the impossible here? Or more likely, am I overlooking the basic fundamentals of the RS-232c port?
This would be my first foray into utilizing this port, and I would only want to use it if I could some how control it wireless on my network. So far everything else I have can be, just not this AVR.
Any help would greatly be appreciated!
Not the Momma! is offline
post #2 of 12 Old 05-11-2012, 07:20 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Yes, you can do this. Thee question is how expensive network controller will be. It is possible that hardware and software cost will justify upgrade to modetn receiver. For the hardware side you may look at old network terminal server sold on e-bay or similar place. They are commonly used to control serverd in data centers. Old 8 port unit shouldn't be that expensive, but they need wired connection. I suspect that you can find a device made for your purpose with wi-fi, but it will likely end up significantly more expensive due to low demand and lack of second hand market.
ap1 is offline
post #3 of 12 Old 05-11-2012, 07:24 AM - Thread Starter
Thanks for the reply.
I've looked at the converter to wireless and wired and it looks like its only around $50-$100 for that piece of the equation.
I would be controlling everything from an Android based tablet like a Kindle Fire or something similar. I imagine additionally irule could be programmed accordingly to send protocols to the avr.
Am I missing something?
post #4 of 12 Old 05-11-2012, 07:28 AM
Super Moderator
markrubin's Avatar
Quoted: 1049 Post(s)
Liked: 2302
I think all you need is a Global Cache device: iTach series includes wireless to RS232 controlled by iRule or similar program
there is some latency (delay) going through the wireless iTach device
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
post #5 of 12 Old 05-11-2012, 07:49 AM - Thread Starter
What I was thinking was maybe something like this
And then plug into my home modem from there. Technically since its plugged into the port wouldnt it assign an IP Address for the AVR? From there I can use iRule to define the device and go from there i think
post #6 of 12 Old 05-11-2012, 07:50 AM - Thread Starter
Ah Mark... thank you for chiming in... i was reading up on some other posts that you contributed to and was thinking to myself... Oh, I hope he sees my distress call and lends a helping hand
post #7 of 12 Old 05-11-2012, 07:53 AM
Super Moderator
markrubin's Avatar
Liked: 2302
that looks like a wired CAT 5 to serial adapter: that will not work:you need an external device to generate the IP address such as the iTach
post #8 of 12 Old 05-11-2012, 07:56 AM - Thread Starter
Thanks Mark for the clarification... I was just trying to see if it was possible...
So basically all i need is this Global Cache device:
Global Cache IP2SL iTach Wired TCP/IP to Serial
And the iRule app.
Then just figure out the protocols... will have to find the Marantz ones somewhere and then I should be in the money right?
post #9 of 12 Old 05-11-2012, 08:00 AM
Super Moderator
markrubin's Avatar
Liked: 2302
And the iRule app.
yes that will work: and you will find the codes in iRule
for Denon and Marantz, the serial codes are the same as IP
post #10 of 12 Old 05-11-2012, 08:06 AM - Thread Starter
Just thinking proactively here... I noticed after going on Global Cache's website that they also have a IR model as well that can control 3 different devices... I think that may be better than the serial control as I actually have 3 devices that are non-IP and could be controlled via IR... Oh man, what a great company they are... I think i'll place an order right now for one of those.
I'll probably even control my popcorn hour with iRule as well.
post #11 of 12 Old 05-11-2012, 08:08 AM
Super Moderator
markrubin's Avatar
Liked: 2302
IR control would probably be a bit easier
post #12 of 12 Old 05-11-2012, 08:11 AM - Thread Starter
Thanks for the confirmation. Much appreciated for the input on this. I will post up with my findings once the hardware comes in.
