Front speakers: Use upper or lower connections - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-17-2012, 01:47 AM - Thread Starter
Jerusalem's Avatar
Very newb question but if there are 2 sets of each red and black on your speakers do you use the upper ones or lower ones to connect to your receiver via speaker wire? And why are there 2 sets?
Jerusalem is offline
post #2 of 7 Old 05-17-2012, 02:40 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
the two sets of posts are for biwiring/biamping - generally considered a waste of time unless you have the means to do it correctly with active cross overs and separate amps and such.
As long as the jumpers are in place it doesn't matter which set you use to connect to your receiver/amp. I use the bottom ones out of habit.
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #3 of 7 Old 05-17-2012, 01:44 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
Yes, and I highlighted the VERY important portion in your reply.
domino92024 is offline
post #4 of 7 Old 05-17-2012, 02:10 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
I suspect it never would have occurred to the OP to remove them!
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #5 of 7 Old 05-17-2012, 03:10 PM
JD in NJ's Avatar
Liked: 37
Ah, but what if they were purchased second-hand and the original owner had removed the jumpers? We don't know enough from the post to say one way or another, but it's probably safest to keep that caveat in place.
JD in NJ is offline
post #6 of 7 Old 05-17-2012, 06:52 PM - Thread Starter
Jerusalem's Avatar
Awesome thanks guys, and I'm assuming jumpers on the metal clips that run from one set of connections to the other? I'm a computer guy just now getting into high end home audio .
post #7 of 7 Old 05-17-2012, 06:54 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
Bingo.
Well, don't get too far in!
mcnarus is offline
