Amplifier gain - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-17-2012, 01:04 PM - Thread Starter
jgman's Avatar
Anything wrong or dangerous by maximizing amplifier gain using test tones in order to enable higher volume levels? Basically Max/+10 all channels. Any risk of over-driving the AMP?
jgman is offline
post #2 of 7 Old 05-17-2012, 01:26 PM
flickhtguru's Avatar
Liked: 111
Is this on a dedicated amp or an AVR?
If its an AVR I know you will get into clipping more easily that way and why boost all the channels that much when turning up the volume can boost output as well.
Shawn
flickhtguru is offline
post #3 of 7 Old 05-17-2012, 02:05 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Your risk of overdriving your amp depends on the level of its input signals and its gain. Large input signals and high gain will get you into trouble faster.
However, your best tools for avoiding overdriving are your ears. Are you an audiophile? Are your ears well-trained? Can you hear when an amplifier is clipping?
Most of the damage that is done by overdriving amplifiers is either accidental or happens when the nut holding the volume control isn't paying attention.
arnyk is offline
post #4 of 7 Old 05-17-2012, 02:24 PM - Thread Starter
jgman's Avatar
Its a Rotel 1068 surround preamp driving a Rotel 1075 amplifier. On certain compressed music streams from Rhapsody I max out the volume on the preamp. Raising the gain allows greater volume/loudness, however, don't want to take any unnecessary risks. Strangely my NAD receiver had a lower wattage rating yet appeared to play louder....not sure why.
jgman is offline
post #5 of 7 Old 05-17-2012, 02:42 PM
Roger Dressler's Avatar
Quoted: 1872 Post(s)
Liked: 1002
If your Rhapsody source is so low, might be worth addressing the problem there. Which client are you using?
Current: Deadwood II Theater
Previous: Deadwood Atmos theater [HTOM]
SSP-800 PLIIx 7.4; Anthem AVM 60 7.4.4, MiniDSP OpenDRC-AN
Aerial Acoustics 7B/CC3B fronts, KEF Ci200QS surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
JVC RS520; Stewart Cima Neve 115"W x 49"H 2.35 screen
Roger Dressler is offline
post #6 of 7 Old 05-17-2012, 02:51 PM
amirm's Avatar
Quoted: 1334 Post(s)
Liked: 741
Roger is right. If you are using a PC, be sure to set the speaker level to 100%. Do not attenuate it there. Use the volume control in the amp.
amirm is offline
post #7 of 7 Old 05-18-2012, 04:24 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
What about uncompressed streams from the same source?
Unnecessary risks for most speakers involves power levels in excess of 50 watts. With most speakers and rooms that would be ear-splitting or if you will a dancing level. I presume that your actual situation is that you aren't getting a good listening level.
I suspect that you've avoided risk to the extent that you can't enjoy your audio system. Turning up the gain control on the amp a fair amount seems to be a reasonable course of action.
The receiver lacked an amplifier gain control, so you couldn't shoot yourself in the foot with it.
If you are really worried about your speakers, get some in-line fuse holders and fuse them for 3-5 amps with regular (not slow blow) fuses. I'll bet that with your current settings, even 1 amp fuses would last forever. ;-)
arnyk is offline
