hum/buzz on speakers help..... - AVS Forum | Home Theater Discussions And Reviews
Old 06-06-2012, 04:31 PM - Thread Starter
pjwinstalls's Avatar
I have a hum/buzz on all my outdoor speakers. I have tried a ground loop isolator that plugs into the rca connectors. If i disconnect the rca cables coming from my media server going to the amps, the buzz goes away. If i plug amp input into something else,, like the rca outs on my dvd player the buzz comes back. Any ideas?
Philip
pjwinstalls is offline
Old 06-07-2012, 06:40 AM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
Just one suggestion for starters: Plug all components into the same circuit. You may have to experiment with the circuit breaker box to find out what receptacles go to what circuit breakers.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
