Can I connect a powered subwoofer to my TV ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-17-2012, 11:11 AM - Thread Starter
AVS2012's Avatar
Can I connect a powered subwoofer to my TV and get bass from tv shows, movies and PS3 ?
I have a Sony Bravia 40ex400 LCD
Here are the specs of the TV ...
Inputs and Outputs -
AC Power Input : 1 (Rear) Pigtail
Analog Audio Input(s) (Total) : 4 (1 Side / 3 Rear)
Audio Out : 1(Rear)
Component Video (Y/Pb/Pr) Input(s) : 2 (Rear) (1 fixed/1 selectable)
Composite Video Input(s) : 2 (1 Side/1 Rear)
Digital Audio Output(s) : Optical Digital Output - 1 (Rear)
HDMI™ Connection(s) (Total) : 4 (2 Side/2 Rear)
HDMI™ PC Input : Yes
PC In (D-Sub) + Audio In (Stereo Mini) : 1(Rear) ( common with HDMI 1) (stereo Mini)
RF Connection Input(s) : 1 (Rear)
USB 2.0 : 1(Side)
Audio Features -
5.1 Channel Audio Out : Yes
5.1ch Through Out (Handycam) : Yes
Alternate Audio (Digital) : yes
Audio Out : Fixed
Auto Mute (on no signal) : Yes
Auto SAP : 20FM/10AM
Clear Voice : Yes
Dolby® : Dolby® Digital
Invisible Speaker (w/Sound Elevation) : Yes
Sound Mode : Dynamic, Standard, Clear Voice, Custom
SteadySound® Automatic Volume Control : Yes
Stereo System : MTS
Surround Effect : Cinema, Music, Live Sports, Game
If I purchase a home powered subwoofer that has RCA Line In Inputs can it work with my TV ? From what Ive read I can just connect RCA jacks from my Audio Out on my TV to the RCA Line In on the subwoofer ? Will that give me bass from tv shows, movies and a PS3 ?? Will there be any sync issues or is it just that simple ?
I just purchased a Sony HT - CT150 soundbar with subwoofer. The sub is perfect but the soundbar sounds basically the same as my TV speakers - which is fine by me - my TV speakers are not that bad. But $250 is a little bit too much just to add a subwoofer. I have the Sub set at 0 and Bass set at 0 and it really kicks. Im in a small 450 sq ft apartment and anything above the 0 rocks the walls and floors - it really is too powerful for my space. I will be taking it back.
So Im not looking for something like a full blown home theater, I just would like to add some bass to the TV I have. Just to have the low rumbles and booms while watching tv shows, movies and games is all I am looking for but I think $250 is too much just for that.
I was looking into these subs....
Pioneer SW-8 (dual RCA input)
Polk Audio PSW10 (dual RCA input)
BIC AMERICA V-80 (single RCA Input)
Logitech Speaker System Z523 with Subwoofer (dual RCA Input)
AVS2012 is offline
post #2 of 9 Old 06-17-2012, 02:09 PM
cel4145's Avatar
Quoted: 2652 Post(s)
Liked: 2984
Yes and maybe. Yet you can plug up one of those subs up to the RCAs if the sub has RCA L/R inputs. But maybe cause your TV may not output sound over the built in speakers if you are using that RCA jack. Take a closer look at your manual, and then see how you configure output over those RCAs. In fact, turn it on if there is an option for that and see if sound still comes out.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #3 of 9 Old 06-18-2012, 07:22 AM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
Almost all TVs shut off the TV speakers when you select the external audio outputs.
You might want to consider spending $150 on a Denon 1312 receiver and get a pair of inexpensive speakers, and connect the sub to the receiver sub output. The Boston CS23 speakers are nice, for $80.
It would almost certainly sound a lot better than the TV speakers and give you a lot more connection options and flexibility.
commsysman is offline
post #4 of 9 Old 06-18-2012, 08:02 PM - Thread Starter
AVS2012's Avatar
Thanks for the replies....
I had RCA jacks connected to the Audio Output on the back of my TV and had headphones connected to them.
I had the headphones connected to a headphone volume control adapter and the adapter connected to a stereo mini jack at the end of the RCA jacks.
These items....
http://www.amazon.com/Koss-155954-VC20-Volume-Control/dp/B00001P4XH/ref=sr_1_1?ie=UTF8&qid=1340070598&sr=8-1&keywords=headphone+volume+control+adapter
http://www.amazon.com/Male-3-5mm-Stereo-Female-Y-Cable/dp/B000I23TTE/ref=sr_1_23?s=electronics&ie=UTF8&qid=1340070701&sr=1-23&keywords=rca+y+adapter
From what I remember is that I had to turn the TV volume down and use the Volume control on the adapter. So the TV volume still worked. I will try it again to make sure, just have to dig out the wires and connect them.
So if the TV volume still works with headphones connected to the TVs Audio Out jacks does that mean if I connected a powered subwoofer it would work ?
I already have to return the Sony soundbar, I really dont want to buy a subwoofer and then end up having to return that also. Plus I see the best deals online for them and probably would end up having to pay return shipping and what not.
AVS2012 is offline
post #5 of 9 Old 06-19-2012, 09:50 AM
scorrpio's Avatar
If TV speakers and RCA outputs both work at the same time, then yes, you can connect a sub to the RCA, set it to whatever crossover desired, and it should work. One problem, though, is you'll have to adjust sub level on the sub itself any time you change TV volume if you want the sub to match the rest of your sound.
scorrpio is offline
post #6 of 9 Old 06-19-2012, 08:05 PM - Thread Starter
AVS2012's Avatar
I would need a actual crossover, like for car audio ? I can deal with manually adjusting the bass, it will be mainly for movies.
Now I still have the Sony Soundbar, so if I connect the RCA Audio Outputs on my TV to the Sonys subwoofers TV Audio In RCA jacks - the subwoofer should work, right ? I will not have the soundbar connected. The subwoofer has all sorts of inputs to select on the menu, not sure if that would make a difference, or if the soundbar HAS to be connected . It should work like a regular powered subwoofer, right ?
AVS2012 is offline
post #7 of 9 Old 06-19-2012, 08:40 PM
cel4145's Avatar
Liked: 2984
Pretty much all home audio subs have a built in amp with a low pass filter crossover so you can set it to kick in where your speakers start to roll off naturally.
Sorry. Don't know anything about soundbars.
post #8 of 9 Old 06-21-2012, 07:56 PM - Thread Starter
AVS2012's Avatar
I tried the subwoofer that came with the CT150 and it worked. It synced up and gave the bass that I wanted.
I hooked up RCA jacks to the Audio Out RCA jacks on the TV then to the RCA Audio In Jacks on the subwoofer and set the subwoofer to TV.
AVS2012 is offline
post #9 of 9 Old 06-21-2012, 08:39 PM
cel4145's Avatar
Liked: 2984
And you should definitely return the soundbar/sub package and get something else. I looked it up, and that soundbar sub is only 5 1/8"--not really much of a sub at all, more of a midbass module. I wouldn't even pay $100 for it.
Here's a very good 8" sub: Mirage Omni S8. It also has the level and crossover dials on the front, making easier to make adjustments as you need to. Should give you some solid lower end bass for an 8" sub in that price range.
