7.1 in weird shape room - AVS Forum | Home Theater Discussions And Reviews
Old 08-03-2012, 04:22 AM - Thread Starter
Skylinestar's Avatar
Quoted: 1046 Post(s)
Liked: 182
living room diagram3.jpg 74k .jpg file
Attached is a general layout of my living hall.
Currently, I have a 5.1 setup for my movies. While most people who stick with 5.1 are having small spaces, how does it fare in larger space like mine?
On my understanding, for 5.1 to work best, the rear wall and the surrounds should not be too far (shown by the orange imaginary line). Perhaps the rear wall is needed for dipole/bipole/monopole surround sound to reflect back and give the enveloping sound. Unfortunately, my rear wall is kinda far from my MLP. Will I benefit much from the 7.1 rear surrounds? Most blurays are still on 5.1, so I'll be using Dolby PL IIx for the proposed 7.1.
Any feedback with greatly appreciated.
Name:	living room diagram3.jpg
Skylinestar is offline
Old 08-03-2012, 04:48 AM
flickhtguru's Avatar
Liked: 110
You definitely have plenty of room behind you for 7.1... If you have the money i say go for it. If you have a receiver with audyssey I'm sure you will notice that the trim level on the rear speakers will be much higher than the rest of the speakers just because of the distance but shouldn't be an issue. I love 7.1 and PLIIx does a great job.
What speakers and sub do you have?
Shawn
flickhtguru is offline
Old 08-03-2012, 05:51 AM
sdurani's Avatar
Quoted: 4479 Post(s)
Liked: 2901
Benefit much? With the back wall so far behind the seating area, you're an ideal candidate for a 7.1-speaker layout, because you'll get excellent rear-vs-side separation in the surround field.
Since your room is 16' wide, that means your side speakers will be 8'-9' from the sweet spot (depending on mounted height). With that in mind, it is not unreasonable to have your rear speakers 12' feet from the sweet spot.
The only suggestion I would make is to place your rear speakers at least 60° apart (roughly 14' spread on the back wall). to make it easier to hear stereo separation behind you (where our hearing is not so good).
Sanjay
sdurani is offline
Old 08-03-2012, 06:32 AM - Thread Starter
Liked: 182
Klipsch Synergy B3, C2, S2 and Rythmik FV15HP.
Old 08-03-2012, 06:47 AM - Thread Starter
Liked: 182
Currently, I have an extra pair of B3 speakers which are used for DSX Front Wide setup (not shown in the attached diagram). Wondering if it's worth to reposition them as rear speakers in 7.1 rolleyes.gif . In that case, I'll have to buy more speaker cables due to the long run...and with larger wire size, price won't be cheap. That's why I need more input whether I should sacrifice the bigger soundstage provided by DSX Wide to jump to 7.1 with better surround.
Old 08-03-2012, 07:09 AM
sdurani's Avatar
Liked: 2901
Your second pair of B3 bookshelves are perfect as rears, since they are more directional than the S2 surrounds and will do a better job of anchoring sounds behind you. As for whether it's worth it, you'll have to demonstrate that for yourself. Place those speakers behind you temporarily (on ladders or a stack of boxes or whatever) and play a good 7.1 soundtrack, like the opening chapter of 'Transformers: Dark of the Moon'.
Sanjay
sdurani is offline
