Room Acoustics & Symmetry - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-03-2012, 12:42 PM - Thread Starter
designmule's Avatar
Quoted: 34 Post(s)
Liked: 24
I have two questions related to room acoustics and symmetry.
1.) My stereo is setup in my living room which has hardwood floors (with a rug), windows, leather furniture, and a bit of echo. The left wall is sheet rock with a handful of pictures on it. The right wall has two windows with blinds covering them. I have a RealTraps 2x4 HF Mini Trap on a stand at the primary reflection point of each wall.
I have the option to hang heavy curtains over the windows on the right wall. I believe that doing so should alleviate some of the echo. However, I am concerned that in a room where the right wall is heavily damped relative to the left wall I might experience some imbalance in the imaging or spatial reproduction.
2.) I could likely add some bass trapping in the front left corner of my listening room. However, I can not add any bass trapping to the right front corner. I'm not really sure if bass trapping needs to be symmetrical or not.
If you've got some experience in the matter, I'd love to hear your thoughts on my two questions.
Thank you
Matt
MRX-520. Mirage OMD-5: left, right & surrounds. Mirage OMD-C1: center. SVS-SB-2000: subwoofer.
Intel NUC running JRiver 21 as DLNA renderer. Samsung BD-C6900. Roku 3.
designmule is offline
post #2 of 10 Old 08-04-2012, 10:23 AM
jim19611961's Avatar
Quoted: 449 Post(s)
Liked: 153
Room symmetry, especially in the proximity of the speakers and those wall surface boundaries between you and the speakers is vital. The general rule is dont do to one side what you cant do to the other (assuming they are equal to start with).
In your case, they are not.
Sounds like if you put the drapes up for the right wall, and take down the reflective pictures on the left wall, and put something there that has more or less the same absorption characteristics as heavy drapes (you could just put the same drapes over the sheetrock btw), then you would have some degree of symmetry.
But keep in mind heavy drapes are only going to affect high and upper midrange frequencies.
My Room
My Music
Rega - Apollo, Rega - DAC, Goldpoint Passive, Classe CA-100, Crown XLS 1002, miniDSP
Jenzen Next
jim19611961 is offline
post #3 of 10 Old 08-04-2012, 12:01 PM
Ethan Winer's Avatar
Quoted: 264 Post(s)
Liked: 359
Jim has the right idea - the front of the room needs to be symmetrical, especially the sides area between your ears and the loudspeakers. Can you put an attractive wall hanging on the wall to match the same in front of the windows? Symmetry with bass trapping isn't so important. Better to put it wherever you can rather than omit some places just for symmetry.
--Ethan
Ethan Winer is offline
post #4 of 10 Old 08-04-2012, 10:36 PM
Skylinestar's Avatar
Quoted: 1056 Post(s)
Liked: 184
--Ethan
I can't comprehend this.
Skylinestar is offline
post #5 of 10 Old 08-05-2012, 08:34 AM
Quoted: 449 Post(s)
Liked: 153
--Ethan
Agreed
My Room
My Music
Jenzen Next
post #6 of 10 Old 08-05-2012, 10:58 AM
Quoted: 264 Post(s)
Liked: 359
--Ethan
I just meant something like a Navajo rug etc, to match something similar on the opposite side.
--Ethan
post #7 of 10 Old 08-05-2012, 11:46 AM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
--Ethan
Like bookcases on one side and louvered blinds on the other?
BTW, what are those acoustic treatments sitting between the speakers? What are the absorption coefficients for those? biggrin.gif
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #8 of 10 Old 08-05-2012, 06:14 PM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
Craig
Those are very realistic puppets from a puppet maker friend of Ethans ..... smile.gif
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #9 of 10 Old 08-06-2012, 10:01 AM
Quoted: 264 Post(s)
Liked: 359
Both sides are more or less reflective, but it doesn't matter because both the window and shelves are forward of the reflection points.
--Ethan
post #10 of 10 Old 08-06-2012, 12:03 PM - Thread Starter
designmule's Avatar
Quoted: 34 Post(s)
Liked: 24
Thanks for the tips everyone. That was kind of what I was thinking but it's nice to have another set of eyes on it.
