Help with Speaker Hz settings. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-03-2012, 08:31 PM - Thread Starter
polk9116's Avatar
I have a Denon AVR-1513 with Polk T15 bookshelf / Polk PSW10 Sub / Polk CS18 center and was wondering if anyone could help me fine tune my reciever. I'm new to having a system and not sure where to set the Hz for each speaker. Also I was a bit confused on the LFE setting and where to set that. Any help would be great!
polk9116 is offline
post #2 of 3 Old 08-04-2012, 10:09 AM
m_vanmeter's Avatar
low end of the Polk T15's is 60 Hz, so I would set the crossover at 80 Hz
I could not find the specs for the CS18, so just start with the same 80 Hz
PSW10 runs 35 Hz to 200 Hz, so I would start at a setting of 120 Hz or higher
You can experiment with the settings, every setup is going to respond differently depending on location and room acoustics
m_vanmeter is offline
post #3 of 3 Old 08-04-2012, 11:52 AM - Thread Starter
polk9116's Avatar
Thanks I will give that a shot.
polk9116 is offline
