Ten Conductor Speaker Wire? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-05-2012, 04:24 PM - Thread Starter
Scooby06's Avatar
I'm wanting to hookup a sound bar that is around 4-6ft from the receiver. I was looking for speaker wire that already has the necessary 10 conductors encased and found out that Polk sells one,but not sure on price or the size of the wire.
I was also thinking about getting some speaker wire and using some techflex,etc to put in it to give it a better look. Not sure as to what size of techflex to get to put 5 separate runs of speaker cable through.If you guys have any other suggestions,let me know.
Scooby06 is offline
post #2 of 6 Old 08-05-2012, 07:29 PM
Colm's Avatar
Liked: 94
You could run 22 AWG wire at that distance.
Colm is offline
post #3 of 6 Old 08-05-2012, 07:35 PM - Thread Starter
Scooby06's Avatar
So get some 22ga wire and wrap it in some sort of braided sleeve?
Scooby06 is offline
post #4 of 6 Old 08-06-2012, 03:27 PM
Colm's Avatar
Liked: 94
Well, various manufacturers make 10 conductor cable. The problem is that you might have to buy 500' or more to get it. IIWY I would just use Cat 6 cable.
Colm is offline
post #5 of 6 Old 08-06-2012, 03:36 PM - Thread Starter
Scooby06's Avatar
Scooby06 is offline
post #6 of 6 Old 08-06-2012, 09:27 PM
Colm's Avatar
Liked: 94
That will work.
Colm is offline
