Ceiling Speaker Array Setup Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-06-2012, 07:59 AM - Thread Starter
electricmba's Avatar
Hi All - I sort of know the answer here but would appreciate some specific instruction or guidance. I am renovating my new home and plan to have a 5.1 or 7.1 surround in my living room off the kitchen, but also would like to run a series of ceiling speakers on the main floor (2 in kitchen, 2 in living room, 2 in office possible 2 in dining room).
I know running 8 speakers from two channels (or possibly 4 channels using the A+B mode) lowers the resistance for the speakers and amp, and that one needs to know what amp and speakers I would be using in order to answer the "how" to wire it.
At present I have a NAD T763 and a Yamaha HTR-5640 as available amps.
My home theater speakers are all PSB Image series from about 6 years ago :
T5's as fronts, B5's as rears, C5 center, Subseries 200.
I am looking at PSB in ceiling speakers, such as this one:
http://www.psbspeakers.com/products/round-in-ceiling/CW60R-In-Wall-Speaker
But if there is a less expensive and suitable ceiling speaker anyone would recommend, I am all ears.
My question is - can I somehow wire up the living room home theater AND in ceilings from the same amp, such that I can listen to music from all speakers at once (say using the T763's 5 channel stereo function) but then isolate just the 5.1 for watching TV or movies. The T763 has a second zone, so would this help or be possible? Going even further, is there hardware/software that would let me isolate sound in specific rooms using a Sonos-like interface (this is a nice to have, not must)?
If there is an amp anyone would recommend or any direction you can give me, I would appreciate it - I also need help with how to wire everything (once the details are ironed out) so i know if I am running in series, which wire connects to what, etc.)
Thanks all.
electricmba is offline
post #2 of 2 Old 08-06-2012, 08:49 AM
underminded999's Avatar
Quoted: 29 Post(s)
I used these for my rear channels: [url]http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10837&cs_id=1083701&p_id=4102&seq=1&format=2[/url]
And these for my side channels: [url]http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10837&cs_id=1083702&p_id=4103&seq=1&format=2[/url]
They work great and for the price couldn't be beat.
As for getting the sound distributed, try a speaker selector: [url]http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10903&cs_id=1090305&p_id=8230&seq=1&format=2[/url]
Just wire the speaker selector to your "B" channel.
Some AVRs will not put out Surround sound, when the "B" speaker is engaged, so just keep that in mind.
underminded999 is offline
