RCA caps - AVS Forum
post #1 of 8 Old 08-15-2012, 10:29 AM - Thread Starter
yaomizzle's Avatar
Liked: 26
Thoughts on using? Counted it up and my receiver alone has 63 unused RCA jacks
Sent from my GT-P7510 using Tapatalk 2
yaomizzle is offline
post #2 of 8 Old 08-15-2012, 10:53 AM
Ratman's Avatar
Quoted: 73 Post(s)
Liked: 235
Do you have an issue? If not... save your $$.
You would probably have more potential to have problems with poor cables/connectors before unused/open RCA ports.
Ratman is offline
post #3 of 8 Old 08-15-2012, 10:56 AM
underminded999's Avatar
That just means that you don't have enough stuff!
Well... then go buy a CD player, Phonograph player, Cassette player, CDR/MD player/recorder, VCR, VCR 2, DVD player, and, and, and....
With the invention of HDMI, the one cable system is a reality.  However, AVRs will still offer many RCA inputs for legacy systems.
The only unused RCA's on the back of my AVR are the pre-outs.  Plus whatever connection are on the front...
As a matter of fact, one of my back RCA plugs is piggy-backing on another.
I however, do not have HDMI on my AVR, but I have a lot of legacy equipment.
Back on subject though, I do not believe that unused RCA connection need to be plugged.
underminded999 is offline
post #4 of 8 Old 08-15-2012, 11:53 AM
arnyk's Avatar
Quoted: 288 Post(s)
Liked: 997
The reason for putting shorting caps on RCA jacks is if you have problems with noise or crosstalk.
This usually would only apply to inputs.
If its not broke, don't fix it!
arnyk is offline
post #5 of 8 Old 08-15-2012, 12:00 PM - Thread Starter
yaomizzle's Avatar
Liked: 26
That's the general consensus that I've gotten...but I'm just looking for was for slight improvement to maximize performance of my my current setup
post #6 of 8 Old 08-15-2012, 04:01 PM
commsysman's Avatar
Quoted: 60 Post(s)
Liked: 239
The best reason for putting caps on them is to prevent corrosion over a period of years, but gold-plated ones do not corrode significantly, so don't worry about those that are gold-plated.
There is no performance issue.
commsysman is offline
post #7 of 8 Old 08-15-2012, 04:05 PM - Thread Starter
yaomizzle's Avatar
Liked: 26
Yeah I have a Yamaha rx-z7 so its all gold plated.
post #8 of 8 Old 08-18-2012, 02:28 PM
Glimmie's Avatar
Quoted: 36 Post(s)
Liked: 163
And even then it's usually just the phono inputs .
Glimmie's HT Page
Being redone - comming soon!
Glimmie is offline
Reply Audio theory, Setup and Chat
User Tag List
