memory foam as a bass trap ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-15-2012, 06:15 PM - Thread Starter
RKreutzer's Avatar
What do you think of memory foam as a bass trap instead of auralex? May be rolled up like a carpet roll and placed in a corner. They come in 2 or 4 inches.
Or do you think it will be too reflective?
RKreutzer is offline
post #2 of 3 Old 08-15-2012, 06:49 PM
gtpsuper24's Avatar
Liked: 99
Foam doesn't do much for the bass and midbass. It would not be too reflective it would absorb too much of the high freqs. Auralex stuff isn't that great either. If you want good bass trapping go with OC 703 fiberglass or some use rolled insulation and roll it in a cyclinder (larger the better, to a point) and stack them in the corners, 16-20" seem to do good. Memory foam is going to be more expensive than the insulation and fiberglass.
gtpsuper24 is offline
post #3 of 3 Old 08-16-2012, 06:25 AM - Thread Starter
RKreutzer's Avatar
Thanks for your info.
